custom token to for authentication drm content
Sep 29, 2011 11:13 AM
We are trying to pass a custom token to for authentication drm content with Flash Access and having issues.
Seems similar to this post: http://forums.adobe.com/thread/879536
But the resolutions are not working for us. We never get DRMState.AUTHENTICATING.
We are using OSMF 1.6 release (I believe we previously tried 1.5 as well). Should note that when using the Flash Access reference application we can get it to work, but that isnt OSMF.
protected function onMediaElementTraitAdd( event:MediaElementEvent ):void
if( event.traitType == MediaTraitType.DRM )
drmTrait = mediaPlayer.media.getTrait( MediaTraitType.DRM ) as DRMTrait;
drmTrait.addEventListener(DRMEvent.DRM_STATE_CHANGE, onDRMTraitDRMStateChange);
At this point drmTrait.drmState = “uninitialized”
I also tried listening to the media player:
  1. player.addEventListener(DRMEvent.DRM_STATE_CHANGE, onDRMStateChange);
The drm state change handler only fires once and its’ drmState is then authenticationError with an error of #3304
    Mar 19, 2012 7:46 AM   in reply to David_RealEyes
    Did you manage to get a solution for this problem? We appear to be having the same issue with OSMF 1.6 and 1.6.1
    Mar 19, 2012 9:03 AM   in reply to David_RealEyes
    Yes, If you could provided src & swc that would be great! We'll give it a go here and see if it helps with our problem.
    Would dropbox.com be fine? I'm not sure if you have my email.
