Hello everyone,
I realize this is an install problem but as of now I have spent over 5 hours with Adobe support and over two hours with Toshiba support, finally sending the laptop back in for testing with no problems found. Just got the unit back and only installed the CS4 suite but still have the same problems:
The problem exists when running Premiere Pro, After Effects or Encore with no other programs running CS4 master suite, all other programs run fine, on a new Toshiba P770 custom build (matchesP770 BT4G22)
All drivers updated from Toshiba site, CS4 updated from help menu.
I would appreciate any information as well as hearing from anyone who is running on a like laptop as I am stuck not knowing if there is a software, Adobe, or hardware, Toshiba problem, I have the same CS4 suit working on my desktop.
Jim, I don't know why laptops use two display adapters but my other laptops show two adapters as well although the adapters are the same where as this unit has two different ones.
I forgot to mention when the HD adapter was disabled PP appeared to operate with a much lower resolution, however the computer did not go to sleep when the lid closed and the max. screen resolution dropped from 1600 x 900 to 1280 x 720 changing the status of the HD back and forth is not an option due working with a blank display.
North America
Asia Pacific
