AE Crash trying to get the user 'language' registry key
Oct 1, 2011 6:31 PM
This is a strange crash I get just opening all sorts of different AE projects.
<140735243008352> <ASL.ResourceUtils.GetLanguageIDFromRegistry> <0> Unable to obtain the User 'Language' registry key at: Software\Adobe\After Effects\10.5.1\ Defaulting to 'en_US'.
It happens on a wide variety of projects just on opening them. Almost all are 720p. but some have footage, others are just PSD or other image files (PNG, JPG). Many of them have trapcode particular 2.1/form 2, but some don't.
I have to find another project, open it, and then hope it doesn't cause a crash. If not, then I can go back and open the project that crashed upon opening and it works fine. It may open a few times without problems, and then upon opening it another time, it will crash with the same warning.
I have a MacPro 2.66 GHz quad-core with 16GB RAM running 10.7.1 with an ATI Radeon HD 4870 card with 512MB of memory.
Seems rather bizarre to crash on trying to get a language registry setting, so any ideas for correcting this would be most helpful.  Thanks.
Pete
    Oct 1, 2011 8:02 PM   in reply to von Elling
    The text of those messages often isn't that useful for showing where the problem is. Often, the error message is just showing you the last logged action.
    Are you using OpenGL rendering? If so, turn it off.
    Are you using third-party plug-ins? If so, which ones?
    I ask this because using OpenGL rendering and using badly behaved (i.e., buggy) third-party plug-ins are the most common reasons for generic errors like this one.
    Oct 1, 2011 8:59 PM   in reply to von Elling
    Make sure that you have the latest updates for the plug-ins. Video Copilot plug-ins, especially, have had some nasty crashes lately.
    Oct 1, 2011 9:24 PM   in reply to von Elling
    Von Elling, I can confirm having the same experience and solution with VCP Optical Flares.
    Dec 8, 2011 9:02 PM   in reply to von Elling
    I'm having a similar issue with After Effects.  I have Adobe After Effects CS5.5 (v.10.5.1) and it keeps crashing when switching between AE and other programs.  Here's a video of what's happening with mine.
    I don't have any special plug-ins loaded except for what came with the program.  OpenGL rendering is turned on and have tried turning it off to see if it make the problem go away and it doesn't make a difference.
    Greatly appreciate any assistance I can get on this.
    Computer System
    • Dell Precision M6600 Laptop
    • Intel(R) Core(TM) i7-2920XM CPU @ 2.50GHz
    • 16GB RAM
    • 2GB NVIDIA Quadro 4000M
      • Driver Version 285.62
      • Optimus is turned off so it's just the Quadro 4000M Card - no Intel HD Graphics in the background
    • 413GB Free (687GB Total) Primary HD
    • 200GB Free (250GB Total) D Drive
    • Windows 7 64-bit SP1 Professional
    • Adobe Master Collection CS5.5 (Website Download)
    • After Effects v.10.5.1 Update (Website Download version)
    Dec 21, 2011 2:52 AM   in reply to Jerrad Gleim
    I have only just installed this and using the trial and am getting the erros on my first use.
    If i can't find a solution then i will most likely be looking for a more compatible product.
    OS is WIndows 7 x64 SP1
    8GB ram
    i5 core processor.
    If anyone has a solution then i would be most grateful.
    Feb 28, 2012 2:03 PM   in reply to mannetbet
    Possible solution to the AE user 'language' registry key crash.
    I was having the same problem. I just tried something that might work for others. I opened AE without any projects. I then imported the project that was crashing, from then on things worked normally. (30 seconds later...) I just opened the project that was saved by that technique and it works normally. I hope this technique works for you too!
    Mar 21, 2012 11:34 AM   in reply to von Elling
    This crash is caused by a corrupt UserWorkspace file.
    ~/Library/Preferences/Adobe/After Effects/10.5/ModifiedWorkspaces/UserWorkspace1.xml
    Take them all out and move them back one at a time until you find the corrupt file.
    Mar 22, 2012 5:01 AM   in reply to scribling@hotmail.com
    i try all this steps and not work for me!!!
    http://forums.adobe.com/thread/978047?tstart=0
    help =/
    Apr 15, 2012 6:41 AM   in reply to dsupremavids
    This worked for me:
    Reset your workspace, Disable GPU rendering in all compositions, AND open optical flares, goto options, in options window goto file -> Preferences -> Disable GPU Rendering. Then goto file and OK changes.
    Hope it helps. For some reason it was still crashing when disabling through the effect window, and only stopped crashing once I disabled it inside the options menu as well.
    Apr 15, 2012 7:45 AM   in reply to von Elling
    Oddly, enough I was getting this error because of an issue with an illustrator file.. It seemed to be corrupt, When loading I noticed I would get this error when it reached that file during loading.. I resaved the illustrator file and it fixed the problem..
    Jul 24, 2012 9:06 AM   in reply to jtw0728
    It definitely was a plugin for me. I had installed the .ico plugin to allow Photoshop to save .ico files. It didn't cause any problems for anything but AE. When I removed that, AE was happy.
    Oct 27, 2013 11:52 PM   in reply to von Elling
    Hey.. Im getting the same error but its only after I installed AEscripts Ease and Wizz.
    and it only happens when I try open the UI panel from the window menu.
    Has anyone had this issue?
    Feb 26, 2014 7:26 PM   in reply to von Elling
    i did try most of  the posts.
    Only thing that 's working for me was importing that project again.
    But it was about 50% chance to not get that error pop up
    and then i replaced all my footages with the same footages again
    For me, it solved the crashing error
