Dreamweaver Spry Image Slideshow - Possible to just use 2 images for the slideshow?
Oct 3, 2011 3:43 AM
Tags: #image #dreamweaver #images #spry #slideshow #2
Hi everyone,
I am in midst of doing a website and have used the Image Slideshow from the Widget Browser as a component of my website. During the development of my site, I realised that the Image Slideshow only start to Autoplay and rotate images with 3 or more images. The slideshow just refuse to work when I have 2 images. Can someone advise me what to do when there is only 2 images? I haved tried looking through the scripts and cannot find a solution. It is giving me a big headache as I am so close to completion but got stucked with this.
Big thanks in advance!
    Nov 4, 2011 9:42 AM   in reply to ProjectJer
    I'd like to be able to use less than 3 images as well.
    Has anyone found a solution?
    Nov 17, 2011 12:17 AM   in reply to ProjectJer
    HI Folks,
    What you need to do is look at the code that is inserted.  Each slide is a list item.  Delete that list item and it will delete the extra images.
    Nov 17, 2011 3:05 PM   in reply to Winginsue
    Thanks for trying to help, but that's not the issue we're having. The widget is coded so that it will only autoload the first image when three or more images are listed. If you only have two items in the unordered list, it will not autoload the first image.
    Apr 20, 2012 2:21 PM   in reply to ProjectJer
    try put on line 456 class SpryImageSlideShow.js
    if(slideIndex==0){
       self.removeClassName(self.element, self.slideShowBusy);
       self.showSlide(self.defaultSlide);
       self.isReady = true;
      if(slideIndex==1){
       if (self.autoPlay)
        self.play();
    Apr 22, 2012 11:44 AM   in reply to Renato Motta
    Thank you! Worked beautifully. Now if I can only find the solution to error 2032 in the Widget Browser!
    Apr 23, 2012 8:03 PM   in reply to ProjectJer
    sorry, in my implantation, to be better, insert a "else" before the code.
    (i'm not a java script programmer, because that this jerry-rig)
    like on line 456 class SpryImageSlideShow.js:
    else{
         if(slideIndex==0){
         if(slideIndex==1){
         if (self.autoPlay)
         self.play();
