Is this normal ?
Win7
Dx11
Nvidia 8400M, driver updated
Please check that Hardware Acceleration is enabled in your settings ui. You can do this by loading any flash content, right click > Settings > Make sure that Enable Hardware Acceleration is checked.
Charbs
What browser are you using? Do you have IE9 software rendering enabled?
It was checked, still softwarre rendering on firefox, chrome and ie9
Thanks for trying that devomatic. We don't expect to blacklist this card, so may I ask you to provide your DxDiag info? Run > DxDiag > Save All Information. You can email that to me directly at aaronc@adobe.com, or post just the computer and graphics information here.
Also can you run the exe found here:
www.playercore.com/Users/aaronc/TheMoleSays.zip
It is an app we made to mimic what drivers Stage3D is finding, and that could shed some light as to why your card is being blacklisted.
Thanks.
Have you received my mail last week ?
Ah, yes I did, sorry it was in my junk inbox. Thank you for prompting me.
Looking at your DxDiag info I see that the installed driver is older than 1/1/2009. I assume the latest drivers you have installed must be the drivers supplied by Dell because the latest available driver from NVIDIA is dated 8/9/2011. Can you try to install the latest driver directly from NVIDIA here:
If you are running 64-bit: http://www.nvidia.com/object/notebook-win7-winvista-64bit-280.26-whql-driver.html
Or 32-bit here: http://www.nvidia.com/object/notebook-win7-winvista-280.26-whql-driver.html
If you are able to install those then you should be able to use HW Acceleration. If you can’t then unfortunately there is no supported way we can make HW Acceleration work on your machine. Dell needs to update their graphics drivers in order to support MoleHill. I would recommend filing a support ticket with them if you aren’t able to update to the NVIDIA drivers.
Sorry for the inconvenience.
I have the same problem.
My Dell drivers are 2008.
Installing the reference drivers from Nvidia worked but now many features of my video card are disabled. The HDMI port doesn't work. And everytime I wakeup from sleep mode the display resets to one monitor with 640x480 mode.
Installing reference drivers for laptops is ALWAYS a bad idea.
What should I do now?
Can I force Flash to use my 2008 drivers?
Thanks.
