techn0_brain
Flash Media Gateway issue on Linux
Oct 6, 2011 5:26 AM
Tags: #start #on #flash #media #linux #fmg #gateway
I have tried to install FMG on linux as per instructions. It installs successfully. But it is not starting up? There no logs created? Anyone having the issues? I have tested on Centos 5.5 32bit, Ubuntu 32bit, and Ubuntu 64bit. Same situation....
    Oct 10, 2011 7:50 PM   in reply to techn0_brain
    System Requirements : Linux CENTOS 5.5 64 bit
    Oct 12, 2011 12:49 AM   in reply to techn0_brain
    I had installed it on Ubuntu and it started but can't register any sip profiles... M trying to register a sip profile on a local asterisk server.
    Any help would be higly apprecited. Thanks..
    Core log files..
    #Start-Date: 2011-10-12 13:03:13
    #Software: Flash Media Gateway 4.5.0.0 release
    #Fields:    DATE        LEVEL    TYPE    THREAD    COMMENT
    2011-10-12::13:03:13.090    INFO    1073742997 CORE    20058    Reading server configurations
    2011-10-12::13:03:13.090    ERROR    1073742997 CORE    20058    License Key is not valid; activating Developer Edition limits.
    2011-10-12::13:03:13.090    DEBUG    1073742997 CORE    20058    Log Level Initialzed at 1
    2011-10-12::13:03:13.093    DEBUG    1073742997 CORE    20058    Loading Plugins.
    2011-10-12::13:03:13.094    ERROR    1073742997 CORE    20058    Error Loading plugin /opt/adobe/fmg/mod/libcodech264.so, Cannot locate the symbol registerPlugins
    2011-10-12::13:03:13.105    DEBUG    1073742997 CORE    20058    FMG Started.
    Oct 12, 2011 2:02 AM   in reply to Buddy-s-world
    It seems to be some network/firewall problem if you can stop firewall temporarily please try doing that and then run Flash Media Gateway again.
    If that doesn’t work  I will suggest you to run wireshark on the machine where Flash Media Gateway is running and restart then send back wireshark capture, conf files and log files. All these information together can help us move further.
    In case running wireshark is not possible set debugSIP tag as true and then restart Flash Media Gateway and send back complete log folder and conf folder file.
    Oct 12, 2011 3:08 AM   in reply to shbansal
    Hi shbansal,
    Please find below log files..
    Sip.xml
    <Profile>
                <profileID> sipGateway </profileID>
                <userName> TestProfile </userName>
                <!-- SIP username used inside Authentication header. This tag is optional and defaults to <userName> -->
                <authUserName> sip_username </authUserName>
                <password> sip_password </password>
                <displayName> TestProfile </displayName>
                <!-- this is the Ip address of remote server where FMG registers -->
                <remoteSipHost> xxx.xxx.xxx.xxx </remoteSipHost>
                <!-- Indicates FMG registers at remote server -->
                <doRegister> 1 </doRegister>
                <context> sipGatewayContext </context>
                <supportedCodecs>
                    <codecID> G711u </codecID>
                </supportedCodecs>
            </Profile>
    Note:-  xxx.xxx.xxx.xxx is my local Ip address also FMG and Asterisk are running on same machine.
    Core logs
    #Start-Date: 2011-10-12 14:55:57
    2011-10-12::14:55:57.428    INFO    1073742997 CORE    2028    Reading server configurations
    2011-10-12::14:55:57.428    ERROR    1073742997 CORE    2028    License Key is not valid; activating Developer Edition limits.
    2011-10-12::14:55:57.432    DEBUG    1073742997 CORE    2028    Log Level Initialzed at 1
    2011-10-12::14:55:57.456    DEBUG    1073742997 CORE    2028    Loading Plugins.
    2011-10-12::14:55:57.457    ERROR    1073742997 CORE    2028    Error Loading plugin /opt/adobe/fmg/mod/libcodech264.so, Cannot locate the symbol registerPlugins
    2011-10-12::14:55:57.824    DEBUG    1073742997 CORE    2028    FMG Started.
    2011-10-12::14:55:57.826    DEBUG    1073742997 RTMP    2028    Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
    2011-10-12::14:55:57.826    DEBUG    1073742997 SIP    2028    Adding Interface address - xxx.xxx.xxx.xxx
    2011-10-12::14:55:57.827    DEBUG    1073742997 SIP    2028    Loading quality level config for device=Tandberg990MXP from /opt/adobe/fmg/conf/videoqualitylevels.xml
    2011-10-12::14:55:57.827    DEBUG    1073742997 SIP    2028    Loading quality level config for device=TandbergEdge95MXP from /opt/adobe/fmg/conf/videoqualitylevels.xml
    2011-10-12::14:55:57.827    DEBUG    1073742997 SIP    2028    Loading quality level config for device=GenericVtcDevice from /opt/adobe/fmg/conf/videoqualitylevels.xml
    2011-10-12::14:55:57.828    DEBUG    1073742997 SIP    2028    registration field not set for profile sipPhone ..setting default to -->Reg to Gib<--
    2011-10-12::14:55:57.829    DEBUG    1073742997 RTMP    2028    Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
    2011-10-12::14:55:57.847    INFO    1073742997 RTMP    2028    Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
    2011-10-12::14:55:57.855    DEBUG    1073742997 SIP    2028    Error : could not resolve the address (sip-phone-ip:5060) error no. :
    2011-10-12::14:55:57.855    DEBUG    1073742997 SIP    2028    sip Domain address not set...
    2011-10-12::14:55:57.855    DEBUG    1073742997 SIP    2028    registration field not set for profile sipPhone2 ..setting default to -->Reg to Gib<--
    2011-10-12::14:55:57.855    DEBUG    1073742997 SIP    2028    Could not get Local Interface addr - default MG Address : xxx.xxx.xxx.xxx is used
    2011-10-12::14:55:57.868    WARNING    1073742997 CONTROL    2028    No remote HTTP host or pass specified in fmsmg.xml, exiting discoverHttp
    2011-10-12::14:55:57.872    INFO    1073742997 FMS detected IPv6 protocol stack!
    2011-10-12::14:55:57.873    INFO    1073742997 FMS config <NetworkingIPv6 enable=false>
    2011-10-12::14:55:57.873    INFO    1073742997 FMS running in IPv4 protocol stack mode!
    2011-10-12::14:55:57.873    INFO    1073742997 Host: ubuntu IPv4: 127.0.0.1
    2011-10-12::14:55:57.874    DEBUG    1073742997 SIP    2028    Error : could not resolve the address (sip-gw-ip:5060) error no. :
    2011-10-12::14:55:57.874    DEBUG    1073742997 SIP    2028    Could not get Local Interface addr - default MG Address : xxx.xxx.xxx.xxx is used
    2011-10-12::14:55:57.874    DEBUG    1073742997 SIP    2028    sip Domain address not set...
    2011-10-12::14:55:57.874    DEBUG    1073742997 SIP    2028    registration field not set for profile sipVideoPhone ..setting default to -->Reg to Gib<--
    2011-10-12::14:55:57.926    ERROR    1073742997 SIP    2028    Error : Sip stack could not be constructed : -1
    2011-10-12::14:55:58.875    INFO    1073742935 /opt/adobe/fmg/conf/http.xml
    2011-10-12::14:56:07.847    DEBUG    1073742997 RTMP    2028    Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
    2011-10-12::14:56:07.847    INFO    1073742997 RTMP    2028    Connection Failed: Registry Connection to rtmp://localhost/registry/telephony
    2011-10-12::15:09:57.238    DEBUG    1073742997 RTMP    2028    Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
    2011-10-12::15:09:57.238    INFO    1073742997 RTMP    2028    Connection Failed: Registry Connection to rtmp://localhost/registry/telephony
    2011-10-12::15:09:57.238    INFO    1073742997 RTMP    2028    Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
    2011-10-12::15:09:57.239    DEBUG    1073742997 RTMP    2028    Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
    2011-10-12::15:09:57.239    INFO    1073742997 RTMP    2028    Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
    2011-10-12::15:10:07.239    DEBUG    1073742997 RTMP    2028    Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
    2011-10-12::15:10:07.239    INFO    1073742997 RTMP    2028    Connection Failed: Registry Connection to rtmp://localhost/registry/telephony
    2011-10-12::15:10:07.239    INFO    1073742997 RTMP    2028    Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
    2011-10-12::15:10:07.240    DEBUG    1073742997 RTMP    2028    Received onStatus <NetConnection.Connect.Closed> code <status> classType <(null)> description <(null)> details
    2011-10-12::15:10:07.240    INFO    1073742997 RTMP    2028    Connection Failed: Registry Connection to rtmp://localhost/registry/telephony
    2011-10-12::15:10:07.240    INFO    1073742997 RTMP    2028    Connection Failed: Registry Connection to rtmp://localhost/registry/telephony_control
    SIp Logs
    14:55:57.907 -INFO- STACK  - ConstructStackLog - Log was initialized successfully
    14:55:57.908 -INFO- STACK  - Common Core version 1.4.9 (Release)
    14:55:57.908 -INFO- STACK  - OS=Linux ES
    14:55:57.908 -INFO- STACK  - Compiler=GNU-4.1
    14:55:57.908 -INFO- STACK  - Architecture=Little Endian, 64bit
    14:55:57.908 -INFO- STACK  - TIME: Timestamp=Posix, Clock=Linux, Tm=Posix
    14:55:57.908 -INFO- STACK  - THREADS: Semaphore=Posix, Lock=Posix, Mutex=Posix, Thread=Posix
    14:55:57.908 -INFO- STACK  - MEMORY: OsMem=Malloc
    14:55:57.908 -INFO- STACK  - NETWORK: Host=Posix, Select=select(), Socket=BSD, PortRange=Fast, DNS=Ares, TLS=None
    14:55:57.908 -INFO- STACK  - ANSI: 64Ascii=Standard, Assert=Ansi, StdIo=Ansi, LogListener=File&Term
    14:55:57.908 -INFO- STACK  - CHECKS: NULL=on, Range=on, Other=on
    14:55:57.908 -INFO- STACK  - USR_CONFIG: EnableIpv6Tos=no, UseFakedIpv6TClass=no, IpsecEnabled=no
    14:55:57.908 -INFO- STACK  - USR_CONFIG: DnsUsesHosts=yes, DnsUsesCaching=yes, DnsCacheSanity=no
    14:55:57.908 -INFO- STACK  - USR_CONFIG: UsePosixTimestamps=yes, UseRdtscTimestamps=yes, SelectKqueueGroups=no
    14:55:57.908 -INFO- STACK  - USR_CONFIG: EhdHostFile=none, QueueType=standard
    14:55:57.908 -DEBUG  - STACK  - CalculateConfigParams - maxTransmitters - default value 100 was taken instead of -1
    14:55:57.908 -DEBUG  - STACK  - CalculateConfigParams - messagePoolNumofPages - default value 150 was taken
    14:55:57.908 -DEBUG  - STACK  - CalculateConfigParams - generalPoolNumofPages - default value 224 was taken
    14:55:57.908 -DEBUG  - STACK  - CalculateConfigParams - numOfReadBuffers - default value 50 was taken
    14:55:57.908 -DEBUG  - STACK  - CalculateConfigParams - elementPoolNumofPages - default value 80 was taken
    14:55:57.908 -INFO- STACK  - RvSipStackConstruct - RADVISION SIP stack - version 5.5.0.6 - Constructing...
    14:55:57.908 -INFO- RA  - RA_ConstructFrom - (ElementSize=1568,NumOfElements=150,pLogMgr=0x0x7f86c8052c68,name=Mes sagePool)
    14:55:57.908 -INFO- RA  - RA_Clear - (raH=0x0x7f86cc0be040(MessagePool))
    14:55:57.908 -INFO- RPOOL  - RPOOL_CoreConstruct - (elemSize=1536,maxNumOfBlocks=150,allocEmptyBlocks=1,name=MessagePool )=0x0x7f86cc0be020
    14:55:57.908 -INFO- RA  - RA_ConstructFrom - (ElementSize=1056,NumOfElements=224,pLogMgr=0x0x7f86c8052c68,name=Gen eralPool)
    14:55:57.908 -INFO- RA  - RA_Clear - (raH=0x0x7f86cc084040(GeneralPool))
    14:55:57.908 -INFO- RPOOL  - RPOOL_CoreConstruct - (elemSize=1024,maxNumOfBlocks=224,allocEmptyBlocks=1,name=GeneralPool )=0x0x7f86cc084020
    14:55:57.908 -INFO- RA  - RA_ConstructFrom - (ElementSize=288,NumOfElements=236,pLogMgr=0x0x7f86c8052c68,name=Elem entPool)
    14:55:57.908 -INFO- RA  - RA_Clear - (raH=0x0x7f86c8058980(ElementPool))
    14:55:57.908 -INFO- RPOOL  - RPOOL_CoreConstruct - (elemSize=256,maxNumOfBlocks=236,allocEmptyBlocks=1,name=ElementPool) =0x0x7f86c8058960
    14:55:57.908 -INFO- STACK  - StackAllocateMemoryPools - Memory pools were allocated successfully
    14:55:57.909 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c80588a0)
    14:55:57.909 -DEBUG  - STACK  - StackConstructParserModule - parser module constructed
    14:55:57.909 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c804f9b0)
    14:55:57.909 -INFO- MESSAGE- SipMessageMgrConstruct - Message Manager was constructed successfully.
    14:55:57.909 -DEBUG  - STACK  - StackConstructMessageModule - message module constructed
    14:55:57.923 -INFO- TRANSPORT - SipTransportConstruct - Constructing the Transport module
    14:55:57.923 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c8010ee0)
    14:55:57.923 -DEBUG  - TRANSPORT - TransportMgrInitialize - max num of sockets for the stack is: 28
    14:55:57.923 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c801ba90)
    14:55:57.923 -DEBUG  - THREAD - RvThreadConstructFromUserThread(thread=0x7f86c801ba90) - thread was constructed.
    14:55:57.923 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c8011680)
    14:55:57.923 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c800d3a0)
    14:55:57.923 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c80588e0)
    14:55:57.923 -INFO- RLIST  - RLIST_PoolListConstruct - (TotalNumberOfUserElements=285,TotalNumberOfLists=1,UserDataRecSize=8 ,name=OORPool)
    14:55:57.923 -INFO- RA  - RA_ConstructFrom - (ElementSize=16,NumOfElements=1,pLogMgr=0x0x7f86c8052c68,name=OORPool )
    14:55:57.923 -INFO- RA  - RA_Clear - (raH=0x0x7f86c8002330(OORPool))
    14:55:57.923 -INFO- RA  - RA_ConstructFrom - (ElementSize=32,NumOfElements=285,pLogMgr=0x0x7f86c8052c68,name=OORPo ol)
    14:55:57.923 -INFO- RA  - RA_Clear - (raH=0x0x7f86c8054f80(OORPool))
    14:55:57.923 -INFO- RLIST  - RLIST_PoolListConstruct - (TotalNumberOfUserElements=285,TotalNumberOfLists=1,UserDataRecSize=8 ,name=OORPool)=0x0x7f86c804f9f0
    14:55:57.923 -INFO- RLIST  - RLIST_ListConstruct - (pListPool=0x0x7f86c804f9f0)
    14:55:57.923 -INFO- RA  - RA_ConstructFrom - (ElementSize=4096,NumOfElements=1,pLogMgr=0x0x7f86c8052c68,name=SendB uffer)
    14:55:57.924 -INFO- RA  - RA_Clear - (raH=0x0x7f86c8017d70(SendBuffer))
    14:55:57.924 -INFO- RA  - RA_ConstructFrom - (ElementSize=4096,NumOfElements=1,pLogMgr=0x0x7f86c8052c68,name=RecvB uffer)
    14:55:57.924 -INFO- RA  - RA_Clear - (raH=0x0x7f86c80166e0(RecvBuffer))
    14:55:57.924 -INFO- MEMORY - RvMemoryAlloc(block allocated=0x7f86c800bc80)
    14:55:57.924 -INFO- RLIST  - RLIST_PoolListConstruct - (TotalNumberOfUserElements=3,TotalNumberOfLists=1,UserDataRecSize=240 ,name=LocalAddressesPool)
    14:55:57.924 -INFO- RA  - RA_ConstructFrom - (ElementSize=16,NumOfElements=1,pLogMgr=0x0x7f86c8052c68,name=LocalAd dressesPool)
    14:55:57.924 -INFO- RA  - RA_Clear - (raH=0x0x7f86c80013b0(LocalAddressesPool))
    14:55:57.924 -INFO- RA  - RA_ConstructFrom - (ElementSize=264,NumOfElements=3,pLogMgr=0x0x7f86c8052c68,name=LocalA ddressesPool)
    14:55:57.924 -INFO- RA  - RA_Clear - (raH=0x0x7f86c8018e40(LocalAddressesPool))
    14:55:57.924 -INFO- RLIST  - RLIST_PoolListConstruct - (TotalNumberOfUserElements=3,TotalNumberOfLists=1,UserDataRecSize=240 ,name=LocalAddressesPool)=0x0x7f86c8011440
    14:55:57.924 -INFO- RLIST  - RLIST_ListConstruct - (pListPool=0x0x7f86c8011440)
    14:55:57.924 -INFO- TRANSPORT - TransportMgrAddLocalAddressToList - UDP Local Address xxx.xxx.xxx.xxx:5060 (0x0x7f86c8018f00) was added to list
    14:55:57.924 -INFO- TRANSPORT - TransportMgrAddLocalAddressToList - UDP Local Address 127.0.0.1:5060 (0x0x7f86c8019008) was added to list
    14:55:57.924 -ERROR  - SOCKET - RvSocketBind(sock=36,addr=xxx.xxx.xxx.xxx:5060,scopeId=-1,range=(nil) ,useRange=0,errno=98)=-2145371137
    14:55:57.924 -ERROR  - TRANSPORT - TransportUDPOpen (Local Address 0x0x7f86c8018f00): can't bind UDP socket -1 (crv=-2145371137,rv=-1:UNKNOWN)
    14:55:57.924 -ERROR  - TRANSPORT - LocalAddressOpen - Failed to open local UDP address xxx.xxx.xxx.xxx:5060 (0x0x7f86c8018f00). rv=-1
    14:55:57.924 -ERROR  - TRANSPORT - OpenLocalAddressesFromList - Failed to open local UDP address xxx.xxx.xxx.xxx:5060 (0x0x7f86c8018f00). rv=-1
    14:55:57.924 -ERROR  - TRANSPORT - OpenLocalAddresses - Failed to open UDP addresses (rv=-1)
    14:55:57.924 -ERROR  - TRANSPORT - TransportMgrInitialize - Failed to open local addresses
    14:55:57.924 -ERROR  - TRANSPORT - SipTransportConstruct - Failed - destructing the module
    14:55:57.924 -DEBUG  - TRANSPORT - TransportMgrDestruct - Destructing the transport manager
    14:55:57.924 -INFO- RLIST  - RLIST_PoolListDestruct - (pListPool=0x0x7f86c8011440)
    14:55:57.924 -INFO- RA  - RA_Destruct - (raH=0x0x7f86c8018e40(LocalAddressesPool))
    14:55:57.924 -INFO- RA  - RA_Destruct - (raH=0x0x7f86c80013b0(LocalAddressesPool))
    14:55:57.924 -INFO- RA  - RA_Destruct - (raH=0x0x7f86c8017d70(SendBuffer))
    14:55:57.924 -INFO- RA  - RA_Destruct - (raH=0x0x7f86c80166e0(RecvBuffer))
    14:55:57.924 -INFO- RLIST  - RLIST_PoolListDestruct - (pListPool=0x0x7f86c804f9f0)
    14:55:57.924 -INFO- RA  - RA_Destruct - (raH=0x0x7f86c8054f80(OORPool))
    14:55:57.924 -INFO- RA  - RA_Destruct - (raH=0x0x7f86c8002330(OORPool))
    14:55:57.924 -ERROR  - STACK  - StackConstructTransportModule - The transport module couldn't be constructed
    14:55:57.924 -ERROR  - STACK  - StackConstructModules - The Transport module couldn't be constructed, rv=-1
    14:55:57.924 -ERROR  - STACK  - RvSipStackConstruct - Failed to construct stack modules. The supplied configuration was:
    14:55:57.924 -INFO- STACK  - [======Compilation Parameters=========]
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - RELEASE = on
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - RV_SIP_SUBS_ON = on
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - RV_SIP_AUTH_ON = on
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - RV_SIP_HIGHAVAL_ON = on
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - RV_SIP_TEL_URI_SUPPORT = on
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - RV_SIP_OTHER_URI_SUPPORT = on
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - RV_THREADNESS_TYPE = RV_THREADNESS_MULTI
    14:55:57.924 -INFO- STACK  - [======Stack objects allocation=========]
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - maxCallLegs = 30
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - maxTransactions = 60
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - maxTransmitters = 100
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - maxRegClients = 20
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - maxPubClients = 2
    14:55:57.924 -INFO- STACK  - [=======Memory pools allocation=========]
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - messagePoolNumofPages = 150
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - messagePoolPageSize = 1536
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - generalPoolNumofPages = 224
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - generalPoolPageSize = 1024
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - elementPoolNumofPages = 236
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - elementPoolPageSize = 256
    14:55:57.924 -INFO- STACK  - [=======Network parameters==============]
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - bIgnoreLocalAddresses = 0
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - maxNumOfLocalAddresses = 3
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - localUdpAddress = xxx.xxx.xxx.xxx
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - localUdpPort = 5060
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - numOfExtraUdpAddresses = 1
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - tcpEnabled = 0
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - localTcpAddress = 0.0.0.0
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - localTcpPort = 5060
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - numOfExtraTcpAddresses = 0
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - maxConnections = 20
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - ePersistencyLevel = -1
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - connectionCapacityPercent = 0
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - serverConnectionTimeout = -1
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - DLAEnabled = 1
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - outboundProxyIpAddress =
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - outboundProxyHostName = None
    14:55:57.924 -INFO- STACK  - PrintConfigParamsToLog - outboundProxyPort = 5060
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - eOutboundProxyTransport = -1
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - sendReceiveBufferSize = 4096
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - socketSendReceiveBufferSize = 32768
    14:55:57.925 -INFO- STACK  - [======Transaction behavior=============]
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - bUseRportParamInVia = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - bDynamicInviteHandling = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - enableServerAuth = 1
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - maxAuthObj = 156
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - bDisableMerging = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - bOldInviteHandling = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - bResolveTelUrls = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - strDialPlanSuffix = NULL
    14:55:57.925 -INFO- STACK  - [======Call-Leg behavior================]
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - manualAckOn2xx = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - manualPrack = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - bEnableForking = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - forkedAckTrxTimeout = 32000
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - forked1xxTimerTimeout = -1
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - manualBehavior = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - enableInviteProceedingTimeoutState = 1
    14:55:57.925 -INFO- STACK  - [======Multi-Threaded parameters========]
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - numberOfProcessingThreads = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - processingQueueSize = 100
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - numOfReadBuffers = 50
    14:55:57.925 -INFO- STACK  - [======Timers configuration=============]
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - retransmissionT1 = 500
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - retransmissionT2 = 4000
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - generalLingerTimer = 8000
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - inviteLingerTimer = 8000
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - provisionalTimer = 180000
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - retransmissionT4 = 5000
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - cancelGeneralNoResponseTimer = -1
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - cancelInviteNoResponseTimer = -1
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - generalRequestTimeoutTimer = -1
    14:55:57.925 -INFO- STACK  - [======Proxy Timers configuration========]
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - isProxy = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - proxy2xxRcvdTimer = 32000
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - proxy2xxSentTimer = 0
    14:55:57.925 -INFO- STACK  - [======DNS parameters====================]
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - maxElementsInSingleDnsList = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - maxDnsDomains = 30
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - maxDnsServers = 30
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - maxDnsBuffLen = 4096
    14:55:57.925 -INFO- STACK  - [======Extension support=================]
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - rejectUnsupportedExtensions = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - addSupportedListToMsg = 1
    14:55:57.925 -INFO- STACK  - [======Session Timer behavior============]
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - sessionExpires = 1800
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - minSE = -1
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - manualSessionTimer = 0
    14:55:57.925 -INFO- STACK  - [======Subscription behavior=============]
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - maxSubscriptions = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - subsAlertTimer = 5000
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - subsNoNotifyTimer = 32000
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - subsAutoRefresh = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - bDisableRefer3515Behavior = 0
    14:55:57.925 -INFO- STACK  - PrintConfigParamsToLog - enableSubsForking = 0
    14:55:57.925 -INFO- STACK - [================General Log Filters===================]
    14:55:57.925 -INFO- STACK  - General Filters - default Filter = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - General Filters - core Filter =
    14:55:57.925 -INFO- STACK  - General Filters - ads Filter  =
    14:55:57.925 -INFO- STACK  - [================Modules Log Filters===================]
    14:55:57.925 -INFO- STACK  - Module Filters - CALL= INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - TRANSACTION  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - MESSAGE= INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - TRANSPORT = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - TRANSPORTIMER = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - PARSER = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - STACK  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - MSGBUILDER= INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - AUTH= INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - TRANSC_CLIENT = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - REG_CLIENT= INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - PUB_CLIENT= INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - SUBS= INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - COMPARTMENT  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - RESOLVER  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - TRANSMITTER  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - SECURITY  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - SEC AGREE = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - RLIST  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - RA  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - RPOOL  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - HASH= INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - PQUEUE = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - SEMA4  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - MUTEX  = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - LOCK= INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - MEMORY = INFO,DEBUG,WARN,ERROR,EXCEP
    14:55:57.925 -INFO- STACK  - Module Filters - THREAD = INFO,DEBUG,WARN,ERROR,EXCEP
    Jan 18, 2012 10:00 PM   in reply to techn0_brain
    I suggest you to go through the following link, it might be helpful for you. Thanks.
    markusbe.com/2009/09/installing-flash-media-server-on-ubuntu-linux/
    vpn service
    Jan 18, 2012 10:10 PM   in reply to jantanik
    Thanks for the reply.. I got it working.. It was issue with the SIP gateway password.. .. My gateway password was having "&#" which are reserved keywords in xml.. I changed my password and it worked fine...
    Feb 1, 2012 1:52 AM   in reply to techn0_brain
    Hi Buddy! Its really good to hear from you, thanks for your response.
    vpn android
