Save image path to MySQL and store file
Oct 7, 2011 3:36 AM
Hi there,
I have a form that saves data to a MySQL db. In this form there are four input type file to upload images.
Everything is made with the Dreamweaver wizard.
What I need to do is to store the file path into MySQL and the file into a folder of the website.
I assume that I need to change in GetSQLValueString($_POST['variable'], "text"), but I don't know how to do it.
Anyone can help???
Thank you VERY mcuh
Jaume
    Oct 10, 2011 10:28 AM   in reply to jaumeH
    Hi Jaume,
    I can't claim credit for this - I got it from here
    So want you want to do is upload an image, saving the image itself within your site and the image name in your database.
    I haven't figured a way to do this in Dreamweaver wizards, without amending the code, but it's quite straightforward.
    Assuming you have a form for people to upload an image, and a new folder within your 'images' folder named 'uploads'...
    Using the Dreamweaver server behaviours will have added loads of hidden code to the top of your page, so you need to use the 'code' view to see this (or 'split' if you'd prefer to see both code and design views).
    On your form page (mine's called add.php), within the code at the very top of your page which will begin with <?php
    and end with
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
    Add in the following code:
     $target = "../images/uploads/";  //This is the directory where images will be saved//
     $target = $target . basename( $_FILES['image']['name']);   //change the image and name to whatever your database fields are called//
    Your Dreamweaver wizard will have created the $_POST details needed for each field.  You need to change the one related to your image to a $_FILES rather than $_POST - look for the line that says something like this (depending on your fields):
    if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
      $insertSQL = sprintf("INSERT INTO database_name (name, Product_No, image) VALUES (%s, %s, %s)",
                           GetSQLValueString($_POST['Name'], "text"),
                           GetSQLValueString($_POST['Product_No'], "text"),
                           GetSQLValueString($_POST['image'], "text"));
    And change the last line to this:
    GetSQLValueString($_FILES['image']['name'], "text"));
    That tells the form to insert the file to a specified location, and to insert the image's name - as text - into the database.  Now you need to specifiy the location:
      //This code writes the photo to the server//
    if(move_uploaded_file($_FILES['image']['tmp_name'], $target))
    //And confirms it has worked//
    echo "The file ". basename( $_FILES['uploadedfile']['name']). " has been uploaded, and your information has been added to the directory";
    else {
    //Gives error if not correct//
    echo "Sorry, there was a problem uploading your file.";
    So your amended php will now look like this:
    else {
    Now in your HTML within the form, your code should look something like this:
    <label for="image">Image</label>
          <input name="image" type="file" id="image" value="<?php echo $row_add['image']; ?>" />
        </p>
        <p>
          <input type="Submit" name="Add" id="add" value="Add" />
          <input type="hidden" name="MM_insert" value="form1" />
      </form>
    To display the uploaded images on your website, just put in the location and echo the image field, remembering your ALT tag:
    <img src="images/uploads/<?php echo $row_get['image']; ?>" alt="<?php echo $row_get['name']; ?>" /></a>
    Good luck!
    Oct 11, 2011 7:46 AM   in reply to jaumeH
    Hi Jaume,
    The $target bit on mine is inbetween the $editFormAction  and the if ((isst... To be honest I don't know that it matters where it goes, but it works there on mine!
    So that bit of code would look like this:
      $editFormAction = $_SERVER['PHP_SELF'];
     if (isset($_SERVER['QUERY_STRING'])) {
      $editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
    if ((isset($_POST["MM_update"])) && ($_POST["MM_update"] == "UpdateForm")) {
    If it has worked, you'll end up with just the image's name (eg image.jpg) in your database field and the image file itself within your Dreamweaver site's images folder.
    Oct 12, 2011 9:19 AM   in reply to goldbecca
    Just for something to think about, I've always been divided/uncertain if saving the path with the filename is the best way to go. If anything, I think I would at least store the filename in a separate column. The reason being that often, you don't always know where the page will be that will eventually link to the file and document relative links then may not work.
    The path can be added to the image source string at any time - either as a static or dynamic value.
    Oct 12, 2011 9:59 AM   in reply to Lon Winters
    I would never store the pathname like that.  Just add it in the static HTML on the page.
    Oct 13, 2011 5:33 AM   in reply to jaumeH
    I thought it would be hard to store the pic in the MySQL so I decided to upload the file to ther server and save the path in the db.
    What do you think???
    I think this is the right way to do it, except just save the image NAME - put the path in the static HTML, e.g.,
    <img src="path_to_the_image_location/<?php echo $image_file_name; ?>"
    That way if you ever change the image location, you only have to change that one line not every record in the database.
    Oct 13, 2011 9:46 AM   in reply to jaumeH
    And, to go fully not state the obvious, the image file name value will come from a recordset in most situations.
    One way to do it if you're working with a detail page for example, is to create the recordset as you normally would for a detail page, using the unique recordID that's passed from the master page. Insert an image placeholder and for the source, click the lightning bolt icon for dynamic data and select the image file name column from the recordset. Then add the path in manually so it ends up like what Murray posted.
    The image placeholder will also add height and width attributes that default to 32x32. So if all the images are the same size, change the attributes accordingly. If they're not the same size, and here's something I should know - will removing those attributes altogether just display the image in it's native dimensions?
    Oct 13, 2011 10:00 AM   in reply to Lon Winters
    Yes.  If the various images are going to have different dimensions, then you will either have to also store the dimensions in the database, or just remove them from the image tag altogether as you have suggested. You can also use PHP to get the image's dimensions, but that seems like a long walk around the park for this purpose.
    Oct 13, 2011 10:24 AM   in reply to MurraySummers
    Then comes the issue of what the dimensions of the images actually are. Going back to the top of the thread, they are user uploaded images, so that means they can come in just about any size and resolution. So the uploading process should also include resizing to a maximum width and/or height.
    Oct 13, 2011 1:59 PM   in reply to Lon Winters
    Certainly - always.
    Oct 14, 2011 3:51 AM   in reply to jaumeH
    Can this be done with dreamweaver????
    That is not the question.  You should ask "Can this be done with PHP", and the answer is yes, sure.  Google "PHP image resize" - you'll find lots....
    Oct 16, 2011 9:49 PM   in reply to jaumeH
    Oct 17, 2011 3:02 AM   in reply to jaumeH
    Yes if this is the only time you are going to do that I'm agreeing with you, it is very expensive. But for a regular webdesigner I don't think it is worth to spend days to find a solution on the internet expecially when you have to face situations like that many times and any time with different details, if it is true that "time is money" it would be much more expensive to spend weeks or months to find a solution that you could have at your finger tips. After all regular webdesigners don't love coding.
    Of course I don't know your state so, in one way such a solution may be expensive on the other way it is not, but that was just a suggestion.
    Thanks to you
    Feb 7, 2013 7:01 AM   in reply to jaumeH
    Hi, sorry for my english, my english is very bad
    My code, as the code is exposed:
    // Variables
    # Definiendo la carpeta #
    $target = "productos/";
    # Definiendo la variable IMAGEN #
    $mat_img = $_FILES['mat_img']['name'];
    # Haciendo que funcione! #
    $target = $target . basename( $_FILES['mat_img']['name']);
    // Insert dreamweaver
    // change $_FILES['mat_img']['name'], "text"),
    GetSQLValueString($_FILES['mat_img']['name'], "text"),
    // And finish
    if(move_uploaded_file($_FILES['mat_img']['tmp_name'], $target))
    mysql_select_db($database_adis, $adis);
    # Ejectutar la consulta para insertar! #
      $Result1 = mysql_query($insertSQL, $adis) or die(mysql_error());
      $insertGoTo = "bien.php";
        $insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
        $insertGoTo .= $_SERVER['QUERY_STRING'];
      header(sprintf("Location: %s", $insertGoTo));
    # Si todo salio exito!, mostar mensaje! #
    echo "The file ". basename( $_FILES['mat_img']['name']). " has been uploaded, and your information has been added to the directory";
    else {
    # Y si no, mostrar un mensaje! #
    // Code Complete
    <?php
    if (!function_exists("GetSQLValueString")) {
    function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
      if (PHP_VERSION < 6) {
        $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
      $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
      switch ($theType) {
        case "text":
          $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
          break;
        case "long":
        case "int":
          $theValue = ($theValue != "") ? intval($theValue) : "NULL";
          break;
        case "double":
          $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
          break;
        case "date":
          break;
        case "defined":
          $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
          break;
      return $theValue;
    if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form")) {
      $insertSQL = sprintf("INSERT INTO material (mat_tipo, mat_fecha, mat_numero, mat_codigo, mat_deta1, mat_deta2, mat_img, idcolaborador, idciudad, idlocal, direccion, hora, costo, fechapanel, idestado) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
                           GetSQLValueString($_POST['mat_tipo'], "int"),
                           GetSQLValueString($_POST['mat_fecha'], "text"),
                           GetSQLValueString($_POST['mat_numero'], "text"),
                           GetSQLValueString($_POST['mat_codigo'], "text"),
                           GetSQLValueString($_POST['mat_deta1'], "text"),
                           GetSQLValueString($_POST['mat_deta2'], "text"),
                           GetSQLValueString($_POST['idcolaborador'], "int"),
                           GetSQLValueString($_POST['idciudad'], "int"),
                           GetSQLValueString($_POST['idlocal'], "int"),
                           GetSQLValueString($_POST['direccion'], "text"),
                           GetSQLValueString($_POST['hora'], "text"),
                           GetSQLValueString($_POST['costo'], "text"),
                           GetSQLValueString($_POST['fechapanel'], "text"),
                           GetSQLValueString($_POST['idestado'], "int"));
    # Si todo salio OK, copiar la imagen a la carpeta definida #
    else {
    $query_disertante = "SELECT * FROM colaboradores";
    $disertante = mysql_query($query_disertante, $adis) or die(mysql_error());
    $row_disertante = mysql_fetch_assoc($disertante);
    $totalRows_disertante = mysql_num_rows($disertante);
    $query_ciudad = "SELECT * FROM ciudades";
    $ciudad = mysql_query($query_ciudad, $adis) or die(mysql_error());
    $row_ciudad = mysql_fetch_assoc($ciudad);
    $totalRows_ciudad = mysql_num_rows($ciudad);
    $query_locales = "SELECT * FROM locales";
    $locales = mysql_query($query_locales, $adis) or die(mysql_error());
    $row_locales = mysql_fetch_assoc($locales);
    $totalRows_locales = mysql_num_rows($locales);
    Hope you are useful!
