Starry173173
Have to reinstall Flash after every reboot.
Oct 12, 2011 5:17 PM
Tags: #flash #ie9 #11
Windows 7 - IE9 - Flash version 11.0.1.152 - Plugins and OS up to date - ESET Smart Securty 4
I get prompted to install new version of Flash after a reboot, so it happens at least once a day.
I install Flash and it installs just fine and works until the PC boots up again.
I tried some of the following:
- Use Adobe Flash Uninstall program before installing
- Using standalone install program
- Checked ActiveX Filter and it was off...turning it on causes
   this same behavior, but the problem I have has nothing to do with the filter
Not sure when this started, but the user didn't have this problem until recently.
I am using ESET Smart Security 4. On all our systems, and his PC is the only
one that is having a problem. Need some pretty hard evidence before I bother
with uninstalling ESET just to see if that would help.
The part that is really strange...if I go to manage add-on's while it is working,
I see the Flash player there and Adobe's name there and that it is enabled.
After I reboot and go into the add-on manager, Flash is still there and still
enabled, but it now says "Unknown" instead of "Adobe" and is no longer
listed near the other Adobe programs. But then, when I reinstall it, that gets
"fixed" and now says Adobe again. So it almost seems like an IE9 problem
and possibly a corruption problem. No known problems with the PC. I suppose
that reloading the PC from scratch would fix the problem...at least I hope it would,
but I'm also not ready to do major surgery if there is an easier fix.
    Oct 12, 2011 10:39 PM   in reply to Starry173173
    I have seen this issue several times in the forums over the last few days, and I do not know what is causing this.
    So far, in every case the installation seems to be complete, and all files are present in the installation folders.
    Could it be that the ocx/dll gets unregistered during the reboot?
    What Windows edition do you have - 32-bit or 64-bit?  What IE9 edition do you use - 32-bit or 64-bit?
    Could you help me with an experiment to determine the possible cause?
    Oct 13, 2011 6:14 PM   in reply to Starry173173
    Starry173173 wrote:
    There were two files (therefore registered):
    C:\Windows\system32\Macromed\Flash\Flash11c.ocx
    C:\Windows\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe
    Are you sure about this?  Wasn't it rather the FlashUtil11c_ActiveX.dll instead of .exe?
    Oct 14, 2011 9:38 PM   in reply to Starry173173
    I also downloaded that Nirsoft tool, and on my (64-bit) system I also only see the ocx and exe registered.  But everything works well on my system.
    So I currently have no other ideas.  Hopefully someone from the Adobe team will have a look at this topic.
    Oct 14, 2011 9:40 PM   in reply to Pat Willener
    sorry no hablo ingless
    Date: Fri, 14 Oct 2011 22:39:15 -0600
    To: j_luis74@hotmail.com
    Subject: Re: Have to reinstall Flash after every reboot. Have to reinstall Flash after every reboot.
        created by ʇɐb ɹəuəllıʍ in Using Flash Player - View the full discussion
    I also downloaded that Nirsoft tool, and on my (64-bit) system I also only see the ocx and exe registered.  But everything works well on my system. So I currently have no other ideas.  Hopefully someone from the Adobe team will have a look at this topic.
         Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Re: Have to reinstall Flash after every reboot.
         To unsubscribe from this thread, please visit the message page at Re: Have to reinstall Flash after every reboot.. In the Actions box on the right, click the Stop Email Notifications link.
         Start a new discussion in Using Flash Player by email or at Adobe Forums
      For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
    Oct 14, 2011 10:00 PM   in reply to Aldomax
    Then you need to unsubscribe from this forum; otherwise you will continue to receive notifications in English.
    The Spanish forum is here http://forums.adobe.com/community/international_forums/espanol
    Oct 16, 2011 10:02 AM   in reply to Starry173173
    Try this, download this file (Add Take Control and Ownership Function to Right Click Context Menu) and then go right click on the IE folder and MACROMED folder, press tab takeover and it will be ok.
    • InstallTakeOwnership
      Windows Registry Editor Version 5.00
      [HKEY_CLASSES_ROOT\*\shell\runas]
      @="Take Ownership"
      "NoWorkingDirectory"=""
      [HKEY_CLASSES_ROOT\*\shell\runas\command]
      @="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
      "IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
      [HKEY_CLASSES_ROOT\Directory\shell\runas]
      @="Take Ownership"
      [HKEY_CLASSES_ROOT\Directory\shell\runas\command]
      @="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
      "IsolatedCommand"="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
    • RemoveTakeOwnership
    [-HKEY_CLASSES_ROOT\*\shell\runas]
    [-HKEY_CLASSES_ROOT\Directory\shell\runas]
