smileybkw
New laptop for CS5
Oct 13, 2011 9:41 AM
Okay, so we're ready to finally join the big leagues and move from elements up to the real thing -- both photoshop extended and premiere pro 5.5, plus adding illustrator and after effects, which we hadn't had before.  And of course, we have to upgrade our goofy computer to something that'll actually run the new stuff, and we'd like it to be a laptop if possible.  So, my techie guy came up with a system that looks pretty good to me, but wanted to make sure:
HP Pavilion dv7t Quad Edition:
Windows 7 Professional 64-bit
Intel Quad Core i7-2630QM
1GB GDDR5 Radeon HD 6770M
8GB DDR3 memory
750GB 7200RPM hard drive
17.3" display (1600 x 900)
Blu-ray writer & SuperMulti DVD burner
There’s space in the laptop for a second hard drive so we’ll get more storage at SATA speeds
Plus 2 USB 3.0 ports for more additional drives with speedy connection
Opinions?? Thanks!!!
*Brian
    Oct 13, 2011 10:27 AM   in reply to smileybkw
    Change the ATI for a nVidia GTX-460M, get a second SATA disk and it will work, but you really must need a laptop to take the performance hit over a lower priced and better performing desktop. For the same amount of money you can get way better performance and room to grow from a desktop.
    Oct 13, 2011 2:19 PM   in reply to smileybkw
    Here is the reason why Nvidia cards are preferred in Premiere Pro CS5.x: At this present time the GPU accelerated mode in MPE does not support ATi cards at all. Therefore, systems with ATi cards can run CS5.x only in the software-only mode, which is often 10 to 20 tines slower in timeline renders than the GPU-accelerated mode. In other words, the ATi cards might as well be as slow as or slower than integrated/onboard graphics when it comes to performance in CS5.x.
    And on an LGA 1155 system you do not want to go with a triple-channel 12GB kit because the memory controller on the CPU is only capable of dual-channel operation. Three 4GB sticks will either run in a Flex dual/single-channel mode (where the first 8GB runs in dual-channel and the remaining 4GB runs in single-channel), or they will all run only in single-channel mode (depending on the motherboard BIOS support). Instead, go for a quad-module 16GB kit (or for a laptop, 8GB is the maximum cost-effective RAM capacity because laptops with more than two SO-DIMM slots tend to be on the expensive side).
    Oct 14, 2011 12:59 PM   in reply to smileybkw
    I believe the G74 is the even better one with room for two internal disks. I woiuld also go for Win7 Pro instead of Home, because of the better network support.
    Oct 15, 2011 5:41 PM   in reply to Harm Millaard
    I second the Asus G74SX that Harm suggested.
    Oct 17, 2011 11:44 PM   in reply to smileybkw
    Looks good, but only 2 disks. Look here: Adobe Forums: Generic Guideline for Disk Setup
