After converting some projects from Robo X3 to Robo v8, the appropriate stylesheet is pulled in and all topics appear as they should. However, the respective .chm file(s) display many topics that do not have the stylesheet applied. The same issue occurs when I attempt to build a new project and import HTML files from the older version project(s).
Additional information:
Thank you in advance for your help.
If you look at the Properties of one of the problem topics, is the stylesheet selected on the Appearance tab? If not, select it and regenerate and see if that fixes it.
Also, I just had a memory of a problem from ages ago. It's to do with type="text/css" displaying in HTML view, but not displaying when you open the file in Notepad.
Here's the thread about it:
Fonts and Style Changes in Generated Help
HTH,
Amber
