Flash is installed, but users still get prompted to install
Oct 14, 2011 12:49 PM
Tags: #11 #center #adobe_ #flash_ #system_
I am new to packaging using MS System Center 2007, and my first task was to update Adobe Flash Player on all PC's.  We have a mix of WIndows 7 64 bit and WIndows XP 32 bit PC's.  I wrote a script for the 64 bit PC's and the 32 bit PC's.
I am showing a success rate of over 96% for the 32 bit PC's.  However, people that show a successful push, are still having issues with Adobe Flash Player.  I connect to the PC and what I have seen is both the Adobe Flash Player ActiveX and Plugin version 11 in Add/Remove Programs.  However, when I go any site that needs Flash, I get prompted to install.  One of three things fix the problem.
1.  Go to the About Adobe Flash Player site and the missing pieces install themseleves.
2.  Run the Uninstaller utility (which is already built into the script) directly on the PC
3.  Run the script directly on the PC.
Sometimes one of these will work.  Other times, I have to uninstall from Add/Remove Programs, then rerun the Uninstaller Utility, and then rerun the script.  Even then, i sometimes have issues with a previous install being stuck.
Eventually, I can manually get the install to work and when I go to the About Adobe Flash site, everything is good.  I don't understand why it shows that it is a successful install on System Center,and the PC shows the Flash Player ActiveX and Plugin installed in Add/Remove programs, but still needs to be installed at the Flash site.
ANy help appreciated.
    Oct 14, 2011 6:59 PM   in reply to WMB-mdillon
    Does that happen with all browsers on the affected systems?
    For Internet Explorer, especially IE9, check
    For other browsers check about:plugins if Shockwave Flash is enabled.
    Oct 18, 2011 5:52 PM   in reply to WMB-mdillon
    Even for IE7 & IE8 you should check if Shockwave Flash Object is enabled.
    You should also check what files there are in
    • C:\Windows\system32\Macromed\Flash (32-bit & 64-bit systems)
    • C:\Windows\syswow64\Macromed\Flash (64-bit systems)
    You will also find the FlashInstall.log files in these folders, which can give you some indication what went wrong during the install.
    Oct 27, 2011 8:49 PM   in reply to Pat Willener
    Hi
    I'm also having problems installing Flash 11. I have XP SP3 and ie8. It keeps saying it's installed and when I try Youtube, for example, it says I need to load Flash. How do I tell if Shockwave Flash Object is enabled, and if not, how do I enable it? Nothing shows up in Tools-Manage add-ons.Any help on how to install this would be much appreciated.
    The files in Macromed Flash are Flash 11c.ocx
                                                    FlashInstall.log
                                                   FlashInstall.log.virtual
                                                   FlashUtil11c_Activex.dll
                                                   FlashUtil11c_Activex.exe
                                                   genuinst.exe
                                                    install.log
                                                   KB923789.inf
    There is another folder there "Flash Player Trust" with one file- AdobeXMPFileInfoC55.cfg
    I also have Mozilla and the same problem exists.
    Any ideas
    thanks
    Carl
    Oct 28, 2011 3:58 AM   in reply to cjf36
    Oct 28, 2011 7:41 AM   in reply to Pat Willener
    That page can not be found
    Oct 28, 2011 8:29 PM   in reply to cjf36
    Sorry, the link got somehow corrupted; here is the correct one http://forums.adobe.com/thread/885448
