YannickFR1
How using loaded mesh to create a shape for a rigidbody ?
Oct 16, 2011 10:03 AM
I want to load a mesh, and use its shape in order to create a rigidbody. Is there a solution to pass a vertex array for example to create a shape. If so, what class I need to use ? (com.adobe.pellet.collision.shape.bt... )
I can use a primitive shape for my rigidBody, but I want my object stands on its own faces.
    Nov 3, 2011 3:14 AM   in reply to YannickFR1
    Even, I am looking a way to treat the loaded model (.obj) as rigidbody.
    Basically, I am loading "PalmTrees.obj" and I've rolling ball. I want my ball to interact with these PlamTrees - ball should not cross over the tree.
    Please help.
    Nov 4, 2011 1:38 AM   in reply to bhavesh4u
    I got the reference of SceneNode and now using createRigidBody, I want to convert it to rigidbody - so that I can apply mass.
    But, I am not able to grip the third parameter which says -
    public function createRigidBody( obj:SceneNode, mass:Number, shape:btCollisionShape ):btRigidBody
    // I've reached till here...
    var tree:SceneNode = new SceneNode( "PalmTrees" );
    var rigidTree:PelletRigidBody = mPellet.createRigidBody(tree, 0, WHAT_GOES_HERE??);
    Any idea?
    Nov 5, 2011 3:37 AM   in reply to YannickFR1
    Finally, its done !!!
    Here is the code to extract the mesh data from loaded model and apply rigidBody to it.
    I used "TestPhysicsStaticMesh.as" class from Proscenium Samples folder to get this done.
    _modelLoader = new OBJLoader( "../res/content/PalmTrees/PalmTrees.obj" );
    _modelLoader.addEventListener( Event.COMPLETE, loadComplete);
    protected function loadComplete( event:Event ):void
              var manifest:ModelManifest = _modelLoader.model.addTo( tree );
              var scale:Number = 2;
              for each (var boatMesh:SceneMesh in manifest.meshes)
                        var indices:Vector.<uint> = new Vector.<uint>;
                        var vertices:Vector.<Number> = new Vector.<Number>;
                        var indexVertexArray:btTriangleIndexVertexArray;
                        var shape:btBvhTriangleMeshShape;
                        var boatCollision:SceneNode;
                        var rbody:btRigidBody;
                        boatMesh.getIndexVertexArrayCopyForAllElements( indices, vertices );
                        indexVertexArray = new btTriangleIndexVertexArray( indices.length/3, indices, vertices.length/3, vertices );
                        shape = new btBvhTriangleMeshShape(indexVertexArray,false);
                        boatCollision = new SceneNode;
                        boatMesh.addChild( boatCollision );
                        rbody = mPellet.createRigidBody(boatCollision, 0, shape);
                        shape.setLocalScaling(scale,scale,scale);
                        rbody.worldTransform.origin.setValue(10,0,-20);
                        boatCollision.physicsObject.collisionFlags |= btCollisionObject.CF_STATIC_OBJECT;
                        boatMesh.appendScale(scale,scale,scale);
                        boatMesh.appendTranslation(10,0,-20);
                        scene.addChild( boatMesh );
