Post-processing pipeline causes error when placing "SceneGrid" object into 3D scene
Oct 16, 2011 9:06 PM
Tags: #error #stage3d #proscenium #postprocessing
first want to thank you guys for the great work with proscenium and the awesome features.
I was going through the examples and found a bug. I tried a combination of the examples "TestLines" and "TestPPEncodeDecodeHDR".
The post processing pipeline somehow manipulates the render sates/vertex program in a way it crashes as soon as it should perform the drawTriangles call for a "SceneGrid" object.
It does not seem to be related to my particular post processing setup - I tried TestPPBloom and TestPPEncodeDecodeHDR from the examples. The post processing pipeline seems to work fine with a 3DS model (Teapot) .
  //add grid
  scene.addChild(new SceneGrid());
  //setup post-processing
  if(true) {
instance.createPostProcessingColorBuffer();
instance.colorBuffer.targetSettings.useHDRMapping = true;
instance.colorBuffer.targetSettings.kHDRMapping = 4;
var colorToPrimary:RenderGraphNode = new RenderGraphNodePPElement(instance.colorBuffer, null, RenderGraphNodePPElement.HDR_DECODE, "Decode HDR" );
colorToPrimary.addStaticPrerequisite(instance.colorBuffer.renderGraphN ode);
instance.renderGraphRoot.clearAllPrerequisite( );
instance.renderGraphRoot.addStaticPrerequisite(colorToPrimary);
This gives me the following error:
Error: Error #3607: Stream 2 is set but not used by the current vertex program.
          at flash.display3D::Context3D/drawTriangles()
          at com.adobe.scenegraph::Instance3D/drawTriangles()[D:\Depots\Proscenium \branches\rel\code\Proscenium\src\com\adobe\scenegraph\Instance3D.as:5 37]
          at com.adobe.scenegraph::PB3DCompute/compute()[D:\Depots\Proscenium\bran ches\rel\code\Proscenium\src\com\adobe\scenegraph\PB3DCompute.as:332]
          at com.adobe.scenegraph::RenderGraphNodePPElement/render()[D:\Depots\Pro scenium\branches\rel\code\Proscenium\src\com\adobe\scenegraph\RenderGr aphNodePPElement.as:272]
          at com.adobe.scenegraph::Instance3D/render()[D:\Depots\Proscenium\branch es\rel\code\Proscenium\src\com\adobe\scenegraph\Instance3D.as:304]
          at com.adobe.scenegraph::BasicScene/enterFrameEventHandler()[D:\Depots\P roscenium\branches\rel\code\Proscenium\src\com\adobe\scenegraph\BasicS cene.as:273]
Philipp
Full Source Code:
package
          import com.adobe.scenegraph.*;
          import com.adobe.scenegraph.loaders.*;
          import com.adobe.scenegraph.loaders.collada.*;
          import com.adobe.scenegraph.loaders.obj.*;
          import flash.display.*;
          import flash.display3D.*;
          import flash.events.*;
          import flash.geom.*;
          import flash.utils.*;
          public class TestLinesWithPostProcessing extends BasicScene
  override protected function initModels():void
  //add grid
  //add teapot
//                              var f:Function = function(event:Event):void { (event.target as ModelLoader).model.addTo(scene); }
//                              var loader:OBJLoader = new OBJLoader("res/content/teapot.obj");
//                              loader.addEventListener(Event.COMPLETE, f, false, 0, true);
                              if(true) {
                                        colorToPrimary.addStaticPrerequisite(instance.colorBuffer.renderGraph Node);
  override protected function resetCamera():void
                              scene.activeCamera.identity();
                              scene.activeCamera.lookat(new Vector3D(0, 5, -15), new Vector3D(0, 0, 0), new Vector3D(0, 1, 0));
