Joe Seven
Fun with tabs & numbers
Oct 17, 2011 4:35 PM
Tags: #numbers #align #lists #tabs
Hello,
I am having a really difficult time with tabs today.
I'm  creating a simple table of contents for a brochure, and want to have a list with page numbers, followed by page discription. (see attached image).
I want to have the numbers right-aligning, and the page descriptions left-aligning. I know how to do this with numbered lists, but that won't allow me to enter in my own numbers. I'd just like to do this manually with tabs. I'd also like to avoid using a table (that will be my last resort).
Any help would be very much appreciated.
Thanks!
    Oct 17, 2011 5:30 PM   in reply to Joe Seven
    Set a right tab for the numbers, set a left tab for the description. This looks so straight forward that I can't help but feel I'm missing something. You actually have to enter a tabs before the number and before the description.
    Oct 18, 2011 6:21 AM   in reply to Joe Seven
    Without getting into Tables of Contets features, Paragraph Styles and Character Styles... all of which could help with this, here is how to do it simply and manually.
    Set your type with a Tab before and after the page numbers (see screenshot below)
    Select all your text
    Open the Tab panel
    Click on the Tab panel ruler where you want the page number and chater text to align to. This will set tab stops for each position.
    Select the tab stop for the page numbers, then click the right aligned tab icon in the tab panel (see screenshot)
    Things should now be aligned.
    You can also set the tabs within a Paragraph style. You can use a nested charater style to get the bold text on the numbers. You can use the Table of Contents features to automatically look for certain tagged styles within your document and create a ToC for you.
    -mt
    Oct 18, 2011 10:14 AM   in reply to Joe Seven
    I believe you could use a GREP style for this, but I've personally never worked with them. So, no, what I mentioned was not a GREP style.
    Set up a character style for Bold (no other attributes, unless you want them, in the Character Style).
    Then, set up a Paragraph Style (I called it TOC Entry, but whatever makes sense to you)
    Edit the Tabs (first screen shot) to match how you want the text and numbers to align
    Edit the Drop Caps and Nested Styles section (second screen shot)
    • Set Character Style to your new 'Bold' style
    • Set the other uptions to Up To, 2, Tab Characters
    You can get some really interesting effects using nested styles.
