Opening multipage pdf in CS5?
Oct 18, 2011 4:24 AM
Tags: #multipage_pdf
Hi
I have done some searching and it seems that Illustrator CS5 is not able to open a multipage pdf file.
I came across this plugin (for mac) Convert PDF Pages to Illustrator Artboards
http://rwillustrator.blogspot.com/2011/03/convert-pdf-pages-to-illustr ator.html
My question is do I have to use this workaround to open a multipage pdf file in Illustrator CS5?
It seems like a very natural feature that should be a part of the program and am puzzled that it seems not to be. Hopefully I am wrong. That I just overlooked something.
    Oct 18, 2011 4:48 AM   in reply to Paal Joachim
    I disagree. Unless your PDF were to contain native Illustrator data (which it won't, if created elsewhere or saved without this option from AI) working with such files would be a nightmare - text disapepars or gets converted, there are no layers, stuff gets rasterized, colors shift. Even if you just want to change one page, you'd still suffer the limitations laid out above and your newly created/ updated PDF might not turn out as what you expected at all. AI simply doesn't understand things like structure or semantics. So in all fairness, long before such a feature would have any priority, AI would have to be much smarter in other departments regardless of whether you edit just one page or a whole book and even then there may be limitations - PDF, first and foremost is a delivery/ archival format not meant to be re-edited in the first place. That people do it all the time and want better ways of hacking is a whole different matter... Anyway, no, you're not missing anything. If you wanna hack it, using that script or opening/ placing the PDF page by page is your only option.
    Mylenium
    Oct 18, 2011 5:41 AM   in reply to Paal Joachim
    The best way to open a multipage PDF is with Acrobat or Adobe Reader. You can easily place a multipage PDF into InDesign, however you cannot edit the PDF in InDesign. You can add elements to your InDesign pages and then export to a new PDF. In InDesign CS5 the fastest way to place a multipage PDF is Window> Utilities> Scripts> Multipageimporter (double click). You can do some limited editing to your PDF in Acrobat, or you can use PitStop or some other plugin to do more extensive editing, but it's always best to go back to the program that created the PDF and make your edits there.
    Oct 18, 2011 6:56 AM   in reply to Paal Joachim
    So it might be easier using Indesign for opening a multi page pdf?
    It might, it might not. The same limitations apply as I laid them out for AI. As Luke already said, it's always gonna be a hack of sorts, if there is no "program native"  data appended to the original PDF, meaning essentially an embedded backup copy of your AI or INDD file. Again, PDF was never meant or designed to be editable beyond certain limits and depending on what content from the PDF you actualyl need, it may be easier to rebuild it from scratch or request access to the original files rather than e.g. trying to separate text that has been fused with a background image the hard way. Really depends on what exactly you plan on doing which you haven't told us yet...
    Mylenium
    Oct 18, 2011 7:14 AM   in reply to Paal Joachim
    If ou only need to add something (and not edit), do as already mentioned and place the catalog in an InDesign file, then place your logo and text and export another PDF. You can also place it in Illustrator, but don't open it.
    Oct 18, 2011 7:33 AM   in reply to Paal Joachim
    I think Monika's suggestion would be most efficient and due to how ID embeds placed object probably also retain most of the existing data as vectors and native text. Rasterizing in PS also is of course a way of doing things, but keep in mind that the new PDF may never be as small as probably the original one was, which could be something to consider for online distribution. And of course you completely lose accessibility/ screen reading ability, since there is no text, just one page sized image essentially. If that's of no concern, you could proceed in that direction as well.
    Mylenium
    Oct 18, 2011 4:34 PM   in reply to Paal Joachim
    Don't embed it when placing into Illustrator and you won't have problems with fonts. What you did when opening it in Photoshop is rasterizing it. Especially text elements that have been in the PDF will suffer a lot from rasterizing, because a resolution of about 300 ppi is way too low for crisp text.
    Oct 18, 2011 4:44 PM   in reply to Paal Joachim
    Paal
    the artboard feature is relatively new and when first introduced it was not envisioned as a page type of tool but a way of exporting areas of the canvas as a file for various uses.
    When it was pointed out that this was essenailly the same as a page type tool it became a multi-purpose tool, once that happened then it was pointed out that it would be a good idea to allow one to organize, renumber and export as individual files and some other features.
    Master artboards are not yet available and placing mutilple page pdf as multiple artboard documents are also not here yet but it might be in the future. It would make a lot of sense as you point out.
    But if Adobe did this for AI then they would probably be compelled to bring editting capabilities to pdfs placed in ID and that might be a big task. So it might take sometime for this to happened.
    Of course it may never happen.
    I think it would help AI and ID if AI alone had this capability and AI files could then be smart objects in ID.
