Sam_poly
Creating Eraser over the image
Oct 25, 2011 5:41 AM
I am trying to create the eraser functionlity can you please help me.
My issue -
I drawing with the pencile over the image and want to erase that graphic but not able to suucees please give some solution.
My backgroud page is image and i am adding zoomIn/ZoomOut functionality to image.
Is there solution to erase only graphic part and Image will remain as it is?
I want to create the Eraser like on the following site :- http://pixlr.com/editor/
  • kglad
    Jul 21, 2002
    Oct 25, 2011 7:04 AM   in reply to Sam_poly
    the easiest way is to fake it and use the graphics class'es draw methods to draw background colored lines.
  • kglad
    Jul 21, 2002
    Oct 25, 2011 7:23 AM   in reply to Sam_poly
    you can use the bitmapdata class to change image pixels to transparent.
  • Peter Celuch
    Nov 17, 2005
    Oct 26, 2011 4:56 PM   in reply to kglad
    Hi Sam,
    as kglad suggested, you can manipulate bitmapData of the pencil drawing (assuming the pencil is drawing to bitmapData - fastest / best drawing).
    I created an example where in the background, there's a Bitmap image (just noise for the sake of the experiment but you can load real picture) and on top of that there's a Bitmap filled with semi-transparent red color. As you move your mouse, you erase the red bitmap.
    You can check the example here: http://dev.flashlabs.eu/examples/eraser/
    The code:
    package  {
        import flash.display.Bitmap;
        import flash.display.BitmapData;
        import flash.display.Sprite;
        import flash.events.MouseEvent;
        import flash.geom.Rectangle;
        public class Eraser extends Sprite {
            private var bitmap:Bitmap;
            public function Eraser() {
                var background:Bitmap = createBackground();
                addChild(background);
                bitmap = createBitmap();
                addChild(bitmap);
                stage.addEventListener(MouseEvent.MOUSE_MOVE, mouseMoveHandler);
            protected function mouseMoveHandler(event:MouseEvent):void {
                var bd:BitmapData = bitmap.bitmapData;
                var x:Number = bitmap.mouseX;
                var y:Number = bitmap.mouseY;
                var brushSize:Number = 20;
                bd.fillRect(new Rectangle(x - brushSize / 2, y - brushSize / 2, brushSize, brushSize), 0x00000000);
            public function createBackground():Bitmap {
                var bd:BitmapData = new BitmapData(stage.stageWidth, stage.stageHeight);
                bd.perlinNoise(5, 5, 5, 5, true, true);
                return new Bitmap(bd);
            public function createBitmap():Bitmap {
                var bd:BitmapData = new BitmapData(stage.stageWidth, stage.stageHeight, true, 0xeeFF0000);
    Nov 27, 2011 10:07 PM   in reply to Peter Celuch
    Thanks Peter its working for my application.
  • Peter Celuch
    Nov 17, 2005
    Nov 30, 2011 11:00 AM   in reply to Harshalsden
    I'm glad to hear it. If the question is answered, please do mark it like ANSWERED. Helpful doesn't close the question.
