base URL as string variable
Oct 25, 2011 5:37 AM
Tags: #url #string #variable #as #httpservice #base
I'm trying to get to grips with Flash Builder 4.5 and have been struggling with this problem for a week now, if anyone has some suggestions I would really appreciate it.
I have been looking for a way to pass a string variable to HTTPMultiService for the baseURL path.
I want to pass the test.text field contents to the HTTPMultiService for the baseURL to be the base path but i just get an error.
Is there a way to pass a variable to the base url to be used as the base path?
My code is as follows.
                                 xmlns:mx="library://ns.adobe.com/flex/mx"
                                 xmlns:mypath="services.mypath.*"
                                 xmlns:testing="services.testing.*"
                                 minWidth="955" minHeight="600"
                                 creationComplete="mypath.send()">
          <fx:Script>
                    <![CDATA[
                              import mx.controls.Alert;
                              import mx.events.FlexEvent;
                              import mx.rpc.events.ResultEvent;
                              import services.testing.mypath;
                              import spark.events.TextOperationEvent;
                              protected function mypath_resultHandler(event:ResultEvent):void
                                        OperationResult.token = testing.Operation();
          </fx:Script>
          <fx:Declarations>
                    <s:CallResponder id="OperationResult"/>
        <s:HTTPService id="mypath" url="mypath.xml" resultFormat="e4x" result="mypath_resultHandler(event)"/>
                    <testing:Testing id="testing"
                                                             fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)"
                                                             showBusyCursor="true"/>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:TextArea id="test" x="34" y="264" width="487" height="33"
                                        text="{mypath.lastResult}"/> <<<< This is the variable i want to use which contains the path i wish to use in the class below.
          <s:DataGrid id="mydg" x="50" y="58" requestedRowCount="4">
                    <s:columns>
                              <s:ArrayList>
                                        <s:GridColumn dataField="office" headerText="office"></s:GridColumn>
                                        <s:GridColumn dataField="departmentid" headerText="departmentid"></s:GridColumn>
                                        <s:GridColumn dataField="street" headerText="street"></s:GridColumn>
                                        <s:GridColumn dataField="zipcode" headerText="zipcode"></s:GridColumn>
                                        <s:GridColumn dataField="state" headerText="state"></s:GridColumn>
                                        <s:GridColumn dataField="lastname" headerText="lastname"></s:GridColumn>
                                        <s:GridColumn dataField="firstname" headerText="firstname"></s:GridColumn>
                                        <s:GridColumn dataField="photofile" headerText="photofile"></s:GridColumn>
                                        <s:GridColumn dataField="city" headerText="city"></s:GridColumn>
                                        <s:GridColumn dataField="id" headerText="id"></s:GridColumn>
                                        <s:GridColumn dataField="title" headerText="title"></s:GridColumn>
                                        <s:GridColumn dataField="officephone" headerText="officephone"></s:GridColumn>
                                        <s:GridColumn dataField="email" headerText="email"></s:GridColumn>
                                        <s:GridColumn dataField="cellphone" headerText="cellphone"></s:GridColumn>
                              </s:ArrayList>
                    </s:columns>
                    <s:typicalItem>
                              <fx:Object id="id1" cellphone="cellphone1" city="city1" departmentid="departmentid1"
                                                     email="email1" firstname="firstname1" lastname="lastname1" office="office1"
                                                     officephone="officephone1" photofile="photofile1" state="state1"
                                                     street="street1" title="title1" zipcode="zipcode1"></fx:Object>
                    </s:typicalItem>
                    <s:AsyncListView list="{OperationResult.lastResult}"/>
          </s:DataGrid>
</s:Application>
Super_Testing.as Class
* This is a generated class and is not intended for modification.  To customize behavior
* of this service wrapper you may modify the generated sub-class of this class - Testing.as.
package services.testing
import com.adobe.fiber.core.model_internal;
import com.adobe.fiber.services.wrapper.HTTPServiceWrapper;
import mx.rpc.AbstractOperation;
import mx.rpc.AsyncToken;
import mx.rpc.http.HTTPMultiService;
import mx.rpc.http.Operation;
import valueObjects.Mydata;
import com.adobe.serializers.json.JSONSerializationFilter;
[ExcludeClass]
internal class _Super_Testing extends com.adobe.fiber.services.wrapper.HTTPServiceWrapper
    private static var serializer0:JSONSerializationFilter = new JSONSerializationFilter();
    // Constructor
    public function _Super_Testing()
        // initialize service control
        _serviceControl = new mx.rpc.http.HTTPMultiService("http://server/mytest/");   <<< I want to replace this hard coded baseURL with a variable from the text field test.text.
         var operations:Array = new Array();        the text field is loaded first before the datagrid is triggered but this still gives an error
         var operation:mx.rpc.http.Operation;        if I put the variable in place of the hard coded url string.
         var argsArray:Array;        Any suggestions would be very welcome.
         operation = new mx.rpc.http.Operation(null, "Operation");
         operation.url = "mytest.php";
         operation.method = "GET";
         operation.serializationFilter = serializer0;
         operation.resultElementType = valueObjects.Mydata;
         operations.push(operation);
         _serviceControl.operationList = operations;
         preInitializeService();
         model_internal::initialize();
    //init initialization routine here, child class to override
    protected function preInitializeService():void
      * This method is a generated wrapper used to call the 'Operation' operation. It returns an mx.rpc.AsyncToken whose
      * result property will be populated with the result of the operation when the server response is received.
      * To use this result from MXML code, define a CallResponder component and assign its token property to this method's return value.
      * You can then bind to CallResponder.lastResult or listen for the CallResponder.result or fault events.
      * @see mx.rpc.AsyncToken
      * @see mx.rpc.CallResponder
      * @return an mx.rpc.AsyncToken whose result property will be populated with the result of the operation when the server response is received.
    public function Operation() : mx.rpc.AsyncToken
        var _internal_operation:mx.rpc.AbstractOperation = _serviceControl.getOperation("Operation");
                    var _internal_token:mx.rpc.AsyncToken = _internal_operation.send() ;
        return _internal_token;
