Flex list has no selection color or rollover color after adding an item to it's dataprovider
Oct 27, 2011 9:09 AM
Tags: #list
I have a basic list that uses an item renderer to display images.
If I add an item to the list, on a button click for example, the item gets added to the list perfectly fine but when i rollover/select this newly added item the highlight is not visibe and it actually stays on the list item that was previously selected?
Could anyone shed some light on this really, really anoying issue for me please?
Flexchief
    Oct 27, 2011 9:34 AM   in reply to flexchief
    Please post a simple test case showing your issue. What version of Flex are you on?
    Oct 27, 2011 10:39 AM   in reply to flexchief
    In MX List, if you are adding the same String or object instance, it will screw up the selection and highlighting because it uses UIDs to distinguish between items.
    Oct 27, 2011 9:50 PM   in reply to flexchief
    Use Spark List.  Or generate unique objects.  There isn’t too much utility to having an object occur twice in a dataprovider.
    Oct 27, 2011 10:07 PM   in reply to flexchief
    Thanks for the reply but do you know of any sort of workaround for this problem with UIDs?
    Assuming your dataProvider is filled with a list of strings:
    [Bindable]
    public var dataProvider:IList;
    private static function getListData(items:IList):ILIst
              var source:Array = [];
              for each(var label:String in items)
                        source.push( {label:label} );
              return new ArrayCollection(source);
    <mx:List dataProvider="{getListData(this.dataProvider)}" />
    Oct 28, 2011 2:46 PM   in reply to flexchief
    That is an easy fix..
              for each(var item:Object in items)
                      if(item is String)
                           source.push( {label:item} );
                      else
                            source.push(item);
    But I suppose disabling the selection color all together works too.
