Really!!???!? 86 views and nobody has any idea why the RoboHelp Server is a Cylon?!?!?!
This is all I'm seeing:
Forever.
I can reboot, reinstall everything, curse, pray, cycle power, and nothing changes this behavior. Whether I'm on Server 2003, Server 2008, it still does it.
Anyone?
Original cry for help:
This is the strangest thing. Our RoboHelp server has been working fine for over a month. Suddenly, it stopped accepting new publish attempts: RoboHelp reported that publishing occurred, but the new content never appeared on the server.
After trying a great deal of troubleshooting, we decided to just reinstall RoboServer. Doing so fails consistently now.
Here's what we're doing:
I'm pulling my hair out here.
Any thoughts?
Can you tell us what RHS version you are using? If you are on RHS9 the only supported DB combination (see the link below) is Microsoft Access which is not recommended in a production environment.
The RoboColum(n) | @robocolumn | Colum McAndrew |
Thanks for your response. We're running RoboHelp Server 9.
We've tried this on Server 2003 SP2 32-bit and Server 2008 R2 64-bit, both of which are reported to support Access, according to the table.
At this point, the ability to robustly support a production environment reliably is still only a distant dream because the install doesn't even yet support our internal testing. A fresh, clean install under either OS stated above results in the infinite "Contacting RoboHelp Server" whenever one clicks the Projects tab in Admin. And, of course, publishing fails.
The best we've done is gotten the system up once and had it stay that way for a few weeks, accepting publishing for our internal feasiblity testing, before it hiccupped and failed. It seems to work fine on a locally hosted VM for testing on a single workstation but as soon as the same environment is deployed elsewhere on the network and try to address it, it flakes out.
