I'm running Windows 7 64 bit, but using the 32bit version of IE9. I have installed the Flash player 11.0.1.152, but I can't view videos on youtube or just about anywhere else. It keeps asking me to install the latest version of flash. I uninstalled then reinstalled it, but still not working.
I'm not sure if this started when I upgraded to IE9 not that long ago, or if it's unrelated to that...
Any help would be much appreciated, I'm not really tech savvy!
Amanda
Download the Flash 11 uninstaller:
Windows 64: http://download.macromedia.com/pub/flashplayer/current/uninstall_flash _player_64bit.exe
Download the Flash 11 installer:
Flash Player for Internet Explorer
Exit Internet Explorer.
Run Flash 11 uninstaller.
Restart.
Delete Flash folder in /Windows/SysWow64/Macromed/.
Delete Flash folder in /Windows/System32/Macromed/.
Run Flash 11 installer.
Press Alt and X, pointer on Safety, is ActiveX filtering unchecked?
Press Alt and X, click Manage add-ons, is the Shockwave Flash Object enabled?
ActiveX is unchecked.
Shockwave Flash Object isn't even listed.
You could not find the Shockwave Flash Object after changing Currently loaded add-ons to All add-ons?
What files are in /Windows/SysWOW64/Macromed/Flash/?
No, still not there...
There are:
Folder - FlashPlayerTrust
files - flash11c.ocx
Flash11Install
install
Restart.
Thank you SO much!!
I had uninstalled and reinstalled it, but apparently deleting those two files was the trick!
Thanks again.
