Issue in setting Load balancing for Indesign Server CS5.5
Oct 31, 2011 5:30 AM
Tags: #load_balancing #indeisgn_server
Hi All,
I need to set up load balancing mechanism for Indesign Server CS5.5 on Windows Server 2008 R2(64 bit version).
I have dutifully following all steps defined in "WORKING WITH LOAD BALANCING AND QUEUEING FOR ADOBE INDESIGN CS5 SERVER.pdf"
After running Indesign server using batch file "startup-indesign-server-CORBA-4instances.bat" from "<ID_SDK>\samples\load-balancing-and-queuing-clients\indesignserver-s tartup-scripts", I get only one instance of Indesign Server running. How to run multiple instances of the INDD server ? Is running multiple instance has something to do with type of licensing ?
Now I run Clover.cmd script, I get this screen. I have no idea why its not working. Please help. Please let me know, if the scenario is not clear and more information is required.
Thnx,
D
