Choco_123
Working with percentages in Adobe Acrobat 9 Pro
Oct 31, 2011 1:12 PM
So, I have a quick question. I am new to working with forms in acrobat, and am having a hard time figuring this part out. If anyone can help me, I would greatly appreciate it!
So I have a form that I've created in acrobat 9 pro. Below I have listed "individual 1:" and then "percentage allocation". The "percentage alloctions" are the different form fields for the percentages I've created. For each form field, I limited the values to not exceed 100%. I want individuals filling in this form to be able to fill in the percentages by each of the names without the TOTAL percentage value (of all three together) going over 100%. But...the trick is, I don't have a separate "Total" form field, there's no room for one. So is there a way to make it so the total of the three equals 100% without having a "total" form field?
individaul 1:  percentage allocation
Individual 2: percentage allocation1
Individual 3: percentage allocation2
Please let me know if this makes sense,
    Oct 31, 2011 1:48 PM   in reply to Choco_123
    It's not very clear how you want it to work. Do you want the fields to automatically change their values if the total is bigger than 100%? If so, in what way?
    Or do you just want to inform the user that the total is bigger than 100%?
    Oct 31, 2011 2:33 PM   in reply to Choco_123
    Are those fields set up as percentage fields or as number fields?
    Oct 31, 2011 2:53 PM   in reply to Choco_123
    In that case, let's say the fields are named "Individual1" to ""Individual3". You can use this code as the validate event of ""Individual1" (just adjust the names of the fields in the first line to use it in the other fields):
    var total = Number(getField("Individual2").value) + Number(getField("Individual3").value) + Number(event.value);
    if (total>100) {
        app.alert("The total of the individual fields can't exceed 100%");
        event.rc = false;
    Oct 31, 2011 3:18 PM   in reply to Choco_123
    Sure. Set it to be read-only, and use this code as the custom calculation script:
    event.value = 100 - (Number(getField("Individual1").value) + Number(getField("Individual2").value));
    Oct 31, 2011 3:32 PM   in reply to Choco_123
    Well, you have to remove the validation fields from the other fields... or
    at least change them because it's a different situation.
    Nov 2, 2011 6:29 AM   in reply to Choco_123
    It's possible to do that, but I would reconsider it. The user will receive
    this error message each time they change the value of a field (before they
    change the other value), which can be quite annoying.
    If you do want to implement it, it's basically the exact same code, just
    change the larger -than symbol (>) to smaller-than (<).
    Nov 2, 2011 6:41 AM   in reply to Choco_123
    I'm not clear on what it is you want to achieve now... Do you want to
    prevent the user from entering a value if the total is bigger than 100? Do
    you want just to warn them?
    Nov 2, 2011 6:57 AM   in reply to Choco_123
    There are several options. You can add a validation script that checks if
    all 3 fields are filled-in, and if so displays the error message (if the
    sum is smaller than 100). That would be less annoying...
    Another option is the disclaimer text you've mentioned. You can even place
    it as a hidden text field next to the total field that gets displayed if
    the total is smaller than 100.
    Nov 3, 2011 6:35 AM   in reply to Choco_123
    You really can't do anything without having the Acrobat JavaScript
    Reference, which is available here:
    http://www.adobe.com/devnet/acrobat/javascript.html
    The very latest of the reference (version 10) is inside the Acrobat X SDK
    package.
    To make a field visible or hidden you need to change the value of its
    display property.
    this.getField("Text1").display = display.visible; // make a field visible
    this.getField("Text1").display = display.hidden; // make a field hidden
    Nov 3, 2011 7:15 AM   in reply to Choco_123
    if its easier to have a "total" form field, create one anywhere and just hide it (properties) ...
    G
    Nov 3, 2011 8:27 AM   in reply to Choco_123
    Your statements are not nested properly. It should be:
    var total = Number(getField("individual1").value) + Number(getField("individual2").value) + Number(getField("individual3").value);
    if (total>100) {
        app.alert("The total of the beneficiary fields must equal 100%");
        event.rc = false;
    } else if (total<100) {
         this.getField("statement").display = display.visible;
    } else if (total==100) {
         this.getField("statement").display = display.hidden;
