Thanks in advance for help & resources!
Using CS3 Flash Pro, AS2 or AS3
Once the dynamic TextField is converted to a Movie clip symbol,
access to that TextField is lost / broken.
Could this be a "Class" issue?
How do I enable the dynamic text to be passed into the Movie clip symbol?
Thanks again!
Dale Zki
You are setting the instance of the movieclip?
Type defining the instance of the MovieClip and TextField, we have two instances.
If the textfield is called "myTxt" movieclip and call themselves"MyMC" access by actionscript should look something like this:
AS2: trace (_root.MyMC.MyTxt);
As3: trace (root.MyMC.MyTxt);
That was it?
Thanks for your response;
For clarity, I should perform the following:
Using AS3
On the stage,
insert a "dynamic text" field and label the instance 'myTxt'
Convert to a Movie Symbol and call this 'MyMC'
In an action script layer (AS3)
insert~ trace(root.MyMC.myTxt)
Question, Can I assume to still be able to feed the TextField
by way of the standard .xml file (where I can change the text)?
I'll give it a try....
Dale
North America
Asia Pacific
