TCS 3.5 (FrameMaker 10, RoboHelp HTML, version 9)
Windows XP version 5.1 sp3
Internet Explorer 8.0
My apologizes if this should be in a different forum. Also, from searching I have found that the problem is usually that the DLL has not been loaded -- I have done that. So I am at a loss. Thanks in advance for your help!
Problem: My .chm output does not have a Glossary tab and the Glossary text pop-ups in my topics do not work.
Background: Since I am new to TCS 3.5 I'm going to give my entire process. Quite frankly I'm not even sure if my entire process is correct.
Steps:
Before I began: I loaded the HHActiveX.dll. Here's the proof:
16. In the properties file I selected the Glossary topic that I had set as my default in step 8.
17. Click Save and generate.
Result: In the .chm file (and in View Selected Item in RH) when I click a glossary term in a topic, I get "This program cannot display the webpage". Also, the Glossary tab is not displayed.
Welcome to our community, Linda
In RoboHelp, if you open the Glossary pod (View > Pods > Glossary > Select Glossary) do you see terms and definitions listed there?
If not, that would explain it as the Glossary has no entries.
Assuming it does have entries, you may simply need to enable the tab by clicking View > Pods > Project Set-up. Expanding the Windows section in the pod and double-clicking your CHM window.
A CHM window looks like this:
If you don't see a CHM window, you will need to create one. If you do see a CHM window, double-click it. Then ensure the Glossary is enabled.
Keep us posted! Rick ![]()
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
Hello again
Sorry, but I forgot to add something. You mentioned "Glossary Popups".
The thing is, RoboHelp does not offer that functionality. Assuming you have successfully created a Glossary and you have launched the Glossary Hotspot Wizard, what RoboHelp does is to create "Expanding Hotspots" where it finds the glossary terms. These simply expose text inline. They don't pop the text up.
If you would like to see an option for text popping up, please consider submitting a Wish Form to ask for the feature to be added in a future release. (link to the Wish Form is in my sig)
Cheers... Rick ![]()
Thanks to Ashish, RoboHelp 8 and above do have Glossary popup. See http://blogs.adobe.com/techcomm/2011/10/generating-glossary-astextpopu p.html for the script and an explanation. Thumbs up for Ashish!
Greet,
Willam
L I B!
M R Snakes!
Thanks Willam. I had no idea you worked for Adobe now! Congrats! (all officiously doing blog posts and all) ![]()
Oh, and too bad they can't manage to sort your name. Pity that...
Haven't tried the script myself yet.
Have you ran the Glossary Hotspot wizard before running the script? Did you set the glossary to use? Do you receive an error message? If you follow the steps Ashish pointed out, and it still doesn't work for you, we'll need to do some debugging.
Greet,
Willam
Yeah! I was able to get it to work. I now have glossary pop-ups in my .chm file.
Problem that prevented pop-ups from working: My original FrameMaker files had hypertext markers in them. They were left over from WebWorks. They showed up in RoboHelp has Broken Links. Once I went through the book and deleted all of the broken hypertext markers, the pop-up links started to work.
Problem that prevented Glossary tab from working: Following Captiv8r's instructions earlier in this thread, I needed to enable the Glossary window. Once I did that, the Glossary tab displayed in my output.
Thanks everyone!
Linda
North America
Asia Pacific
