I would like to be able to have the phone numbers in the newsletter I am working on be live links in a PDF and/or ePub, so that when viewed on a smart-phone, all one has to do is click on the number and it dials automatically. I know how to make the web addresses, but haven't figured out phone numbers.
Is it possible, and if so, how?
Thanks!
Hi
I just added it as an action with a clickable link.
Anyhoo - I just tried it in InDesign and it works perfectly both in the PDF on the iPhone and amazingly in iBooks as well, so I'm really grateful for you asking this question!
So probably best to outline how I did it and take it from there.
In InDesign I created some text, and highlighted the part of the text I wanted to be a link (I would also recommend using a character style here so it is obvious to your user that it is a clickable link).
Then using the hyperlinks panel added my number into the URL field as described above.
Next I exported the PDF - I used the interactive export defaults here.
All I did then was upload it onto a server and then downloaded it on to my iPhone (sideloading would work equally well).
I tapped the link and it worked perfectly.
If you don't get any joy this time I will gladly PM you the InDesign file and a PDF you can use.
Here's a link to an ID (CS5.5) file, select the text "here" and look at the URL in the Hyperlinks Panel.
http://dl.dropbox.com/u/21192016/testPhoneLink.indd
Replace the 44 with the country code you are after and then the zeroes with the number you want to use. Remember that it is usual to remove the first zero in the UK (and probably elsewhere) so an STD dialling code of 01458 would become simply 1458. Don't use any spaces in the numbers.
Then try exporting it to an (interactive) PDF and get it onto your iPhone (as per your PM). Should work just fine - you should get a blue 'bubble' asking you if you want to place the call and take it from there.
North America
Asia Pacific
