I was wondering what's the best practice to make something like below, I thought on global variables with if conditionals, but the code is going to be messy. Unfortunately I can't find any tutorial on the internet, I spent hours googling it but everything I found there was nothing to do with this. It's so frustrating because it's really hard to get on without these "special" references.
For instance,
After finishing a level:
Select level screen:
Game: Rubble Trouble Tokyo
Thanks in advance.
If you have your buttons placed on the stage, you can use their name to extract level ID. To cycle through buttons when initializing, you should put them in a holder (MovieClip) and give it a name let's say "levelButtonsHolder".
Name your buttons like this: btn_%LEVEL-ID%
for eaxample: btn_level0, btn_level1, ..., btn_levelN, where "levelX" is ID for a level by which you can instantiate and reference the level.
Then your code should look like:
import flash.events.MouseEvent;
for(var i:int = 0; i < levelButtonsHolder.numChildren; i++) {
var button:MovieClip = levelButtonsHolder.getChildAt(i) as MovieClip;
if(button.name.indexOf("btn_") == -1) continue;
button.addEventListener(MouseEvent.CLICK, levelButton_clickHandler);
function levelButton_clickHandler(event:MouseEvent):void {
var levelID:String = MovieClip(event.currentTarget).name.substr(4);
trace("LOAD LEVEL. Level ID: " + levelID);
If your levels are MovieClips with classes attached to them, you can instantiate them using acquired LevelID. LevelID should be unique part of a level's full qualified class name.
Let's say your levels have classes:
game.levels.Level01
game.levels.Level02
In that case you should give your buttons names:
btn_Level01
btn_Level02
and you should modify the levelButton_clickHandler() function:
import flash.system.ApplicationDomain;
var levelClass:Class = ApplicationDomain.currentDomain.getDefinition("game.levels." + levelID) as Class;
var level:MovieClip = new levelClass();
What is it checking out ?
I also need to check out whether the level is available for the user to play, if so then to place the button on the stage. Because the user can't play Level 2 if he/she didn't win the Level 1.
Looking at you code carefully and learning from them, can I do that, will it work ?
public class Level01 extends Sprite
public static var allowToPlay = false;
public function Level01():void
if(button.name.substr(4).allowToPlay == false) continue;
Thanks so much.
This is just bulletproofing - if, by any mistake you have some piece of graphics, background, whatever in the buttons holder, it sure won't be named "btn_..." and we will not consider it button - continue means "go to next iteration, don't execute further for this item"
public class Level01 extends Sprite { public static var allowToPlay = false; public function Level01():void { } }
for(var i:int = 0; i < levelButtonsHolder.numChildren; i++) { var button:MovieClip = levelButtonsHolder.getChildAt(i) as MovieClip; if(button.name.indexOf("btn_") == -1) continue; if(button.name.substr(4).allowToPlay == false) continue; button.addEventListener(MouseEvent.CLICK, levelButton_clickHandler); }
I wouldn't use static variables. Maybe you could pull that off, but this syntax wouldn't definitely work.
What I would do is create some array with respect to what level user can play. And than compare it against button names.. forexample
var myUserPermissions:Array = [
levelID: "Level01",
allowToPlay: true
levelID: "Level02",
allowToPlay: true
levelID: "Level03",
allowToPlay: false
and then check each button:
if(!canPlayLevel(levelID)) continue;
function canPlayLevel(levelID:String):Boolean {
for(var i:int = 0; i < myUserPermissions.length; i++) {
if(myUserPermissions[i].levelID == levelID) {
return myUserPermissions[i].allowToPlay;
return false;
North America
Asia Pacific
