wintermoone
ERROR: http://get.adobe.com/flashplayer/completeion/aih/?exitcode=0
Nov 5, 2011 7:30 AM
Tags: #flash_player_not_installing #finish_error #completion_error #error_installing
Running Windows XP 32 bit Firefox. (I have also tried running IE, same issues)
I've tried downloading Flash Player 11 and it downloads, gets to the screen that says it was successfully installed and tells me to click "finish".
Then when I click finish, the error pops up:
Windows cannot find 'http://get.adobe.com/flashplayer/completion/aih/?exitcode=0'. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
And then a blank internet explorer page pops up.
And it doesn't install at all!
I have tried uninstalling my previous version of flash, I have tried downloading the plug-in installer. Still no go.
Please help!!!
    Nov 5, 2011 3:15 PM   in reply to wintermoone
    Hi
    I too am having the same problem. Please someone help us..........
    Nov 5, 2011 7:09 PM   in reply to wintermoone
    Hello,
    Can you please provide the FlashInstall.log file located at \windows\system32\macromed\flash?
    What files are in the \windows\system32\macromed\flash directory?
    What kind of internet connection do you have?  Do you use a proxy server?
    Maria
    Nov 16, 2011 3:04 PM   in reply to wintermoone
    I am having the same problem And I need to update my flash player for a site I was invited to by one of my friends. :U
    Dec 1, 2011 11:22 AM   in reply to m_vargas
    Hi
    I am having the same problem downloading Adobe Flash Player 11.1.102.55
    In answer to your question, What files are in the \windows\system32\macromed\flash directory....
    Flash64_11_1_102.ocx
    FlashInstall
    FlashUtil64_11_1_102_ActiveX.dll
    FlashUtil64_11_1_102_Plugin
    NPSWF64_11_1_102.dll
    I connect to the internet @ home via wireless broadband with Sky.
    What can I do?
    Jan 5, 2012 9:11 PM   in reply to m_vargas
    I just had the same error.
    I have broadband.
    in the system 32 dir are
          Flash10e.ocx                                               instal.log                              flash10x.ocx
          FlashUtil10x_ActiveX.dll                   FlashUtil10x_ActiveX.exe                FlashInstal.log
           flashplayer.xpt                                           Flashutil10y_plugin.exe         NPSWF32.dll
    I also notice nothing has happened for a bit on this problem...
    or rather it seems to ce a continuing issue.
    help.
    Jan 6, 2012 4:38 PM   in reply to gendo666
    Try a clean install of Flash Player:
    • go to http://forums.adobe.com/thread/909550 and download
      • the appropriate uninstaller for your system (save to disk)
      • the appropriate installer(s) for your system (save to disk)
    • close all browser windows and run the downloaded uninstaller
    • restart Windows
    • delete any remaining files in C:\Windows\System32\Macromed\Flash
    • if you are on 64-bit Windows, also delete any remaining files in C:\Windows\Syswow64\Macromed\Flash
    • now run the downloaded installer(s)
    If you still have problems, please specify your Windows and browser details.
  • Xircal
    Mar 29, 2011
    Jan 7, 2012 1:09 PM   in reply to wintermoone
    Please help!!!
    Please follow my instructions here to uninstall/then reinstall Flash again: http://forums.adobe.com/message/4081633#4081633#4081633
    If you're not running AVAST antivirus, check this site which lists all the others with instructions on how to disable AV file scanners, web shields etc: http://www.bleepingcomputer.com/forums/topic114351.html
