Hi There
I've been given a media drive full of past projects and media by a client, which contains (among other things) .mov files which Quicktime Player Movie Inspector tells me are XDCam EX720p50 35Mb/s VBR 1280x720, 16 bit integer (little-endian), Stereo 48Khz. The sound plays fine, but the video shows only a red screen with occasional digital-dropout-like square flicking across the screen.
This PC system is newly installed and running OK, and footage of the same type (given the same credentials by Quicktime Player) from a different client plays fine in Premiere
(Quicktime player will open both sets of files and give you the info, but sends you to the extra-codec page)
So my conclusion is there's a problem with the set of files that won't play (rather than the system)
And my question is....
WHAT CAN I DO? Can anyone give me some advice on how I might get these files working? They have been edited before in a previous version of Premiere by another editor, without issue so they should work...
All help appreciated
jON
(Premiere CS5.5, Win 7 64bit, core i7 2600K at 4.8Ghz, 16Gb RAM, GeFore GTX 570)
You can:
If you're interested in the latter, grab MediaInfo and run a report on one of the MOVs; copy and paste from Text view here. I'll take it from there... ![]()
Ace, ta - gonna go the cheap route first at least, see where it goes. Info from MediaInfo as you suggest:
General
Complete name : H:\Videos\Clinuvel Clinical videos\Formulation\Implantation video working files\implant1.mov
Format : MPEG-4
Format_Commercial_IfAny : XDCAM EX 35
Format profile : QuickTime
Codec ID : qt
File size : 1.30 GiB
Duration : 5mn 6s
Overall bit rate mode : Variable
Overall bit rate : 36.5 Mbps
Encoded date : UTC 2010-09-15 08:49:09
Tagged date : UTC 2011-11-07 09:51:50
Writing library : Apple QuickTime
©TSC : 50
©TSZ : 1
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Codec ID : xdva
Codec ID/Hint : XDCAM
Duration : 5mn 6s
Bit rate mode : Variable
Bit rate : 34.9 Mbps
Maximum bit rate : 35.0 Mbps
Width : 1 248 pixels
Original width : 1 280 pixels
Height : 702 pixels
Original height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 50.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.797
Stream size : 1.24 GiB (96%)
Title : Apple Video Mediensteuerung / Apple Alias-Datensteuerung
Language : English
Tagged date : UTC 2010-09-15 08:49:58
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 5mn 6s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 56.1 MiB (4%)
Title : Apple Ton Mediensteuerung / Apple Alias-Datensteuerung
Language : English
Menu
Title : Zeitmarken-Mediensteuerung / Apple Alias-Datensteuerung
Language : English
Encoded date : UTC 2010-09-15 08:49:58
jON
Hi Jon,
OK, this should do it for you: http://www.mediafire.com/file/o13jgho6m4hik0h/xdcamfix.zip
Download that, extract the files to the same folder as your MOVs, and double-click the "xdcamfix.bat" file. Sit back for a few moments while the clips are rewrapped; you'll wind up with MXF files that have dual mono instead of stereo audio (you can remap to stereo after you import into Pr, if you like). This will process all MOVs in the folder, and create MXFs with the same name. Simply import into Premiere Pro, and go to town. Enjoy the cost savings ![]()
(If you get any errors, let me know.)
Hi Colin
Thanks for your help
Unfortunately I can't seem to get this to work - the xdcamfix file creates .mxfs of 0Kb in size, and Premiere won't import them. The .movs seem to be as they were
When trying to import the .mxf file into Premiere, it says "These files are of an unsupported compression type"
I've also downloaded the demo of Calibrated Q XD decode and have that installed, to no effect - the files (the orignal .movs) still show up as red with flickers of digital dropout as they did before
Any suggestions?
jON
OK, put the files from the zip and one of your MOVs into its own folder. Hold down Shift and right-click in the Explorer pane for that folder; select "Open command window here." That will launch a DOS box that is open to the folder you just created.
At the command prompt, type "xdcamfix" (without the quotes) and hit Enter. Some stuff will fly by, and you'll probably get an error message in red text. Let me know what that says.
Do you have a very small test file you could upload somewhere? If you have a small file but no upload location, let me know via PM and I'll get you an FTP access.
Der der... I'm a bonehead ![]()
OK, right-click on the BAT file and select "Edit"--this will open up the batch file for editing in Notepad. Near the end of the script, you'll see a little text blob that says:
0:2:0:0:2:0
Change it to read:
0:1:1:0:2:0
Save the file, and try the batch again; it should work now.
Cool! Glad that worked. If you're interested, the reason that the original batch didn't work was because I had the audio channel mapping wrong; the script was looking for a second audio track, which wasn't there. The source files have a single stereo track, while the MXF output requires mono audio (which I think I mentioned above), so we have to do some rerouting of the input channels in the script. You'll notice that when these MXFs import, Pr reports them as "2 Mono" vs. "Stereo," which is true; just use remapping in Pr if you prefer them as stereo.
Not really sure about why XD Decode didn't work. It should enable decoding of any of the XDCAM flavors. What version of QuickTime Player are you using? The folks at Calibrated are very fast to respond, so you might email their support. I must confess that I don't actually use the product, beyond having tried it out as a demo; when I need to use this kind of footage, I use my hack workaround ![]()
I can certainly see the appeal of your workaround...
I thought it would be good to have the Calibrated codec demo running as the documentation says it works but adds a watermark, so for speed of assessing material I receive (rather than having to re-encode to view) it's a good way forward - I'll buy it when I get to that moment of receiving a large amount of footage that I will need to use at once, making the workaround too slow
I wonder if the Calibrated codec is actually working? No reason why it shouldn't be, just I have no easy way of testing it - I have no footage to hand that I know requires it, and I don't know how to vaildate its presence in Premiere or Afx
I'm using Quicktime 7.7.1 - it originally installed from the iTunes 64bit installer, but in COntrol Panel calls itself Quicktime 32bit - not sure if there's an offical Apple 64bi version of Quicktime for PCs?
jON
QuickTime 7 (for PCs, anyway) is 32-bit; I think QuickTime X which is only available on Macs is 64-bit, but that's a completely different animal. I know that there is some issue with the XD Decode component and Apple HDV files (actually it's an issue in QT7, and not the Calibrated stuff) where you have to use no later than QuickTime 7.6.9, but I don't believe that affects XDCAM files. With XD Decode installed, can you open up one of the files in QuickTime Player? If so, the plug-in is working (at least outside of Pr). I just tried the latest version here, and it seems to be working externally... and it works in Pr CS5.5, as well (with watermark).
You might consider VLC for playback: VideoLAN - VLC. It will playback XDCAM MOVs without requiring the XD Decode plugin ![]()
Colin, I had the same issue and your ffmbc.exe and xdcamfix.bat worked for me! Thank you SO much! I just spent about 3 hours trying everything I could find with no luck until I found this. Fortunately I didn't have to modify or edit the bat file in any way. I simply extracted to the folder with the MOV files and double clicked on the bat file and waited as the mxf files were created.
YOU'RE THE MAN!!!!
I have successfully used a little tool by Convergent Design called File Converter 1.6, XDCAM EX/XDCAM 422, Quicktime MOV to MXF (http://www.convergent-design.com/Products/nanoFlash/Downloads.aspx)
It's a one click conversion tool for those XDCAM EX/XDCAM 422 files that come in a QT container.
I have a similar problem. A friend sent me the .mov files he recordedin the XDCAM 16x9 1920x1080 . I can't import them into my Win7 Premiere Pro. Codec Missing or unavailable. Lots of people seem to have the same proble id using a PC - particularly when they have been sent the .mov files on a hard drive. The folder
I can play the videos using VLC but not on WindowsMedia or DivX (sound only) or with QuickTime ( won't load - needs new software from Adobe plugins)
If this is a codec problem why can VLC play it?
I have checked out the files with MediaInfo and they are slightly different to the above. Are there ary rules to determing the value of the parameter for the bat file for my mov file. I think this looks like stereo but you will recognise the information you would need. I tried the current bat but that has another audio file map.
General
Complete name : P:\H2012 Videos Walter HD\contest.jury.mov
Format : MPEG-4
Commercial name : XDCAM EX 35
Codec ID : qt
File size : 85.4 MiB
Duration : 19s 720ms
Overall bit rate : 36.3 Mbps
Encoded date : UTC 2012-11-15 18:58:16
Tagged date : UTC 2012-11-21 12:46:49
©TSC : 25
©TSZ : 1
Video
Format : MPEG Video
Format settings, GOP : Variable
Codec ID : xdve
Bit rate : 35.0 Mbps
Width : 1 888 pixels
Original width : 1 920 pixels
Height : 1 062 pixels
Original height : 1 080 pixels
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.698
Stream size : 81.7 MiB (96%)
Language : English
Tagged date : UTC 2012-11-15 19:01:34
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : PCM
Codec ID : sowt
Channel positions : Front: L R
Bit depth : 16 bits
Stream size : 3.61 MiB (4%)
Language : English
Tagged date : UTC 2012-11-15 19:01:33
Menu
Language : English
Encoded date : UTC 2012-11-15 19:01:34
They've been converted to movs using Sony's XDCAM utility for Final Cut Pro. VLC can read them because it uses it's own inbuilt decoders, not the system codecs. If you have Final Cut installed they'll play, if you're on a PC you need to use the convergent design convertor, or get the shooter to send you the original media from before they converted it to mov.
The other option is the one Colin mentioned above: http://www.calibratedsoftware.com/QXD.asp
It installs a codec pack that allows you to work with the files. It's probably the easiest way to go, but it's not free. I think they have a free version you can trial to test if it works though, it just puts a watermark over your shots. Good way to test if it's going to solve your problem before you spend any money on it though.
North America
Asia Pacific
