How to wiggle XYZ dimensions separately for Anchor Point
Nov 9, 2011 9:07 AM
I need to wiggle my anchor point with different settings on each axis.  How can I do this?
I want the following:
for x: wiggle(1,1000);
for y: wiggle(.1,1000);
for z: wiggle(100,2);
Can't seem to figure out how to split the axis up.
Thanks!
    Nov 9, 2011 10:09 AM   in reply to Toomany3
    You can split out the X, Y & Z POSITION properties individually:
    http://help.adobe.com/en_US/aftereffects/cs/using/WSB9C92251-D2B9-49de -8B7E-EE981AD17522.html
    That doesn't help with the anchor point, but you can work round that by parenting the layer position to a 3D null... which just happens to have the same position as the layer before doing the parenting.
    You can then wiggle layer position, and animate the null's position if desired.
    Nov 9, 2011 5:01 PM   in reply to Toomany3
    All you're missing is the array:
    x = wiggle(1,1000);
    y = wiggle(.1,1000);
    z =wiggle(100,2);
    [x, y, z]
    or you can break out each axis. Either works.
    Nov 9, 2011 9:01 PM   in reply to Toomany3
    OOPS! forgot to put in the x, y, and z values. Make the last line
    [x[0], y[1], z[2]]
    That's what I get for answering from my iPhone...
    Final expression looks like this;
    x = wiggle(1,1000);
    z =wiggle(100,2);
    [x[0], y[1], z[2]]
