i'm trying to get the rowcount of a cfgrid on cf9, and if 0 switch a message to user.
i've tried a js attached to the onLoad of the cfgrid, keeps throwing Expected ')' and i don't see where?
function getGridData() {
var mygrid = ColdFusion.Grid.getGridObject('cApps');
var mydata = mygrid.getStore();
rowCountVal = mydata.totalLength;
alert(rowCountVal);
thanks for any help
thanks Dan, it's the cfgrid onload thrwoing the error. i've tried:
onload="javascript:getGridData"
onload="javascript:getGridData()"
onload="javascript:getGridData({cfgridaction}, {cfgridrow} {cfgridchanged})"
nothing works
also tried instead the <cfset ajaxOnLoad="getGridData">, it doesn't throw an error but doesn't return the rowcount either
thanks again
Where is your onload code in your document? I'm assuming that if its a regular onLoad attribute of an HTML element (e.g. <Body>, then you don't need the "javascript:" prefix. Otherwise, what happens if you pop an alert box at the top of your getGridData() method and comment out the rest - are you getting the alert box or is the error occuring before the function can even be called?
it's the onLoad attribute of a cfgrid of type HTML
the cfgrid syntax seems to be correct, onLoad="javascript:getGridData()", i'm using one other event for the same grid and it works fine:
onchange="javascript:showData({cfgridaction}, {cfgridrow}, {cfgridchanged})"
nothing happens if i put the alert at the top of the function, get the same error. looks like the error happens before the function executes.
what's worse, i don't think the onLoad event of the grid actually works. i've tried a different method: the cfgrid is bound to the onkeyup event of a text box, srcApps. i've modified this text box like <input type="text" name="srcApps" setTimeout('getGridData()',1000);"> adding a 1 second delay before executing the function.
this works, but only when i type something in srcApps, and only when using <cfset ajaxOnLoad="getGridData"> at the end of the page, not with the grid onLoad event. if i remove the 1 second delay in the srcApps definition, it stops working, which i think proves onLoad never kicks off
thanks
North America
Asia Pacific
