I publish a video stream to FMS 4.5, then I connect via FMS 4.0 and record the stream. However when I record the file, the timestamp metadata is completely wrong and showing a date from 2017 (and yes the time on my server is correct). The error is there both before and after running it through the f4v post processor so that eliminates one cause.
If I use H.264 as the video codec, the date is wrong. If I use Soreson as the video codec, the date is correct.
The first clip is published on 11/11/2011 around 9:40am with FP 11.1 using H.264 as the video codec. However note the timestamp as determined from FFMPEG as completely wrong:
Metadata:
major_brand : f4v
minor_version : 0
compatible_brands: isommp42m4v
creation_time : 2017-03-01 09:20:52
Duration: 00:00:25.31, start: 0.000000, bitrate: 57 kb/s
Stream #0.0(eng): Video: h264 (Main), yuv420p, 320x240 [PAR 1:1 DAR 4:3], 25 kb/s, 5.04 fps, 10 tbr, 1k tbn, 20 tbc
Metadata:
Stream #0.1(eng): Audio: nmos / 0x736F6D6E, 11000 Hz, 1 channels, 21 kb/s
Metadata:
Stream #0.2(eng): Data: amf0 / 0x30666D61
Metadata:
The second clip is published on 11/11/2011 around 9:51 am with FP 11.1 using Sorenson as the video codec. Note the timestamp as determined from FFMPEG is correct:
Metadata:
duration : 122
videocodecid : 2
audiocodecid : 6
canSeekToEnd : false
createdby : FMS 4.0
creationdate : Fri Nov 11 09:51:51 2011
Duration: 00:02:02.20, start: 0.000000, bitrate: N/A
Stream #0.0: Video: flv, yuv420p, 320x240, 1k tbr, 1k tbn, 1k tbc
Stream #0.1: Audio: nellymoser, 11025 Hz, mono, s16
We are experiencing the same issue. Do you have the fix for this?
