panauser
realtime hardware for cinemadng
Nov 11, 2011 1:02 PM
hi,
i have ikonoskop camera which records 1920x1080 prograssive CinemaDNG (RAW) files.To edit files i am using dng inporter and premiere pro cs5.5
but my problem is since cinemadng files are progressive frames it is not possible to edit without rendering files. First i have to render all files (which may take for 1-2 days for a typical music video raw shoots) then start to edit. but it is very time consuming and has risk factor (assume that our mac crashed after 2 days etc)
my configuration is;
2x2.4 Ghz quadcore mac pro
6gb ram
Blackmagic decklink extreme 3d
blackmagic design hdlink pro
nvidea 4800
nvidea 120 graphic card
do you think it is possible to edit in cinemadng files realtime in premiere pro? what kind of hardware do i need?
thanks in advance
    Nov 11, 2011 10:45 PM   in reply to panauser
    Not at this time.
    It's on our list of things to do, but I don't know when we'll get to it :-(
    Lars
    Nov 24, 2011 2:32 AM   in reply to panauser
    I think the best thing you can do is work out a work flow from After Effects to Premier. If you have an AE project with all your DNG clips as seperate sequences you can do two things. Batch render too an editable low res proxy file. Then once you've fiished editing you can use Premiers replace footage command to swap out the sequences for the DNG files in your AE project. After that DaVinci resolve can grade and playback in real time.
