gvimuser
Premiere Elements 10 (Windows): new editing presets for 1080p60/50, burn Bluray/AVCHD at 24p
Nov 12, 2011 10:20 AM
Tags: #1080p50 #1080p60
Hello, all!
I've created a *user-patch* for Windows version of PRE10 (Adobe Premiere Elements 10). It adds the following new features, which were are available in a standard installation of PRE10:
(1)    Editing-presets for 1920x1080p50 and 1920x1080p60 video projects
          (For Panasonic, JVC, and Sony AVCHD2 camcorders)
(2)    burn *native 24p* video onto Bluray-disc and AVCHD-disc
PRE10's default disc-burning presets only output interlaced-video (1920x1080i30), which is perfectly fine for source-footage that is also interlaced. But for progressive (24p) projects, the result is suboptimal.
Now, you can burn native 24p video onto Bluray-disc (or AVCHD disc.)  No need to go through a 2-step process and a third-party authoring program.
(3)    Editing-presets for HDV progressive: 1080p24, 1080p25, 1080p30
(4)     MPEG-4 file share preset for outputing *.MP4 files at 1920x1080p50, 1920x1080p60
Other general improvements include:
(5)     Editing-preset for 5.1-audio AVCHD Lite 720p50 and 720p60
Editing-preset for 5.1-audio AVCHD 1440x1080p24 and 1920x1080p24
(6)     DVD, AVCHD, and Bluray disc burning with higher-quality (448Kbps) stereo-audio
All of the default disc-burning profiles are now now available with Dolby 448Kbps stereo.
Installation
The user-patch comes in a *.zip file.  So you'll need to be comfortable with "unzipping" files into the installation-directory of PRE10.  And you will need Administrator privileges on your PC.  Detailed instructions are in the readme file.
  • The user-patch does not overwrite/replace any of the original files from your PRE10 installation.
  • It adds a bunch of XML files to multiple "preset/" subdirectories.
  • After installation, you still have access to all of the default presets that came with PRE10. (Nothing is lost/removed.)
DOWNLOAD LINKS:
    Premiere Elements 10 presets v1.0 (Windows): premiere10_themissing_presets_10.zip
https://docs.google.com/open?id=0B96CRWkNxmWdNDM4NTY0ZDEtZmFlYS00MWE0L Tk1ODUtYWUyYmJjZmYzZjdi
(For people with the old version of Premiere Elements)
Premiere Elements 9 presets v1.0 (Windows): premiere9_presets_v100.zip
https://docs.google.com/open?id=0B96CRWkNxmWdODIxNTg1OTQtZmZjNS00NzAxL WE0YmQtMjY0YTBkNTRjNmQ4
   ... did this one last year, but can't remember if I posted it.
    May 30, 2012 10:11 AM   in reply to gvimuser
    Hello gvimuser,
    Thanks for creating these modifications!
    One remark though:
    When creating a DVD menu, when an original HD setting is selected then the menu list contains a mix of menu's in HD resolution as well as in SD resolution.
    When I use the HD settings from you, menu's in HD resolution do not appear anymore in the list. Only the SD resolution menu's show up.
    Do you have any idea why this happens? Could it be another setting that needs modification before PRE10 recognises it?
    Thanks.
    Jul 13, 2012 10:19 AM   in reply to gvimuser
    Great update! Easy to install and just what I needed. No need for me to upgrade to Pro anymore! Thanks!
    Jul 13, 2012 12:17 PM   in reply to gvimuser
    Great stuff. Thank you.
    For sharing to a file with Dolby, I selected the +MP4 - H264 1920x1080p 60 preset. In Advanced settings, on the Multiplexer tab, I set Multiplexer to "None, which made Dolby available on the Audio tab. That allows you to save to separate m4v and ac3 files, which can be muxed with tsMuxeR GUI. All 60 fps from the original were there. Yes!
    Nov 14, 2012 5:04 AM   in reply to gvimuser
    Wonderful! Thank you very much for your work.
Bookmarked By (1)
