Hi everyone,
I have a developed a web service, my web service method expects an xml string.
I have a new data connection, which is my wsdl file...
Now my challenge is how do I populate that field with my form's xml,so that my my method can manupulate it.
Secondly, I would like the same button that calls my web service to email the form once the web service has been called, email the form as PDF.
Will really appreciate your assistance.
Ace
Solved! Go to Solution.
Views
Total Likes
You can use the below command to populate a field with the form's XML.
FieldName.rawValue = xfa.data.saveXML("pretty");
To execute the webservice and then send an email,
1. First place Execute button binding to the Webservice and make it either invisible/ hidden
2. Place a normal button on the form and in the click event write code to call the webservice and then send the email.
//Call the webservice button click event
WebserviceExecuteButton.execEvent("click");
//Send an email
event.target.submitForm({cURL:"mailto:"+ strToAddress + "?subject=" + strSubject + "&body=" + strMessage,cSubmitAs:"PDF",cCharset:"utf-8"});
Replace the names with the variables in your form in the above line.
Srini
Views
Total Likes
//Send an email
Srini
Views
Total Likes
Hi Srini,
I was starting to think what I was asking was impossible.
It works perfectly, just the way I wanted :-)
Thanks a lot Srini, you saved me. Thank you
Views
Total Likes
