Premiere seems to perform well during editing. But anytime I export from the timeline, I have to wait up to a minute or so before the export window opens. If I use AME, the same happens, and when it finally opens is grayed out and says "not responding". This goes on for another bit before finally kicking in. Once encoding, it seems to work fine, but seems like it should be faster.
I've done re-installs of the CS, Windows, and even on a new computer. Same problem. I'm working with HDV footage. I have tried using Matrox AVI as well (MX02 Mini installed) but same problem.
There is a conflict with Matrox and the SurCode AC3 codec.
If you're working with CS5 go to C:\Program Files\Adobe\Adobe Media Encoder CS5\MediaIO\codecs and rename the file SurCodeWrapper.vca to SurCodeWrapper.bak, when Premiere or Media Encoder are not running.
Then go to C:\Program Files\Adobe\Adobe Premiere Pro CS5\MediaIO\codecs and do the same thing.
If you're working with CS5.5 go to C:\Program Files\Adobe\Adobe Media Encoder CS5.5\MediaIO\codecs and rename the file SurCodeWrapper.vca to SurCodeWrapper.bak, when Premiere or Media Encoder are not running.
Then go to C:\Program Files\Adobe\Adobe Premiere Pro CS5.5\MediaIO\codecs and do the same thing.
Hope this helps!
North America
Asia Pacific
