micgat
[CS5 Java Corba] Export PDF as PNG - Error 111626 : This is not a valid InDesign Interchange documen
Nov 14, 2011 6:11 AM
i have java web application, that use indesign server to export idml files as PDF.
The workflow:
1. open the idml file
2. export the idml as pdf
3. close the idml file
Sometimes this error occured: Error 111626 : Server cannot open the idml file. This is not a valid InDesign Interchange document.
When this error occures, aftert that the indesign server sends the same error for all following idmls, that I try to export.
The consequent is that I have to stop the server and start it again.
I just have this behaviour only with this error code. For all others errors the server works fine and export all idmls correctly.
What can I do. I don't want to restart the server everytime.
Can you help me ?
Thanks + Cheers
Michèle
    Dec 19, 2011 2:17 AM   in reply to micgat
    Hi Michele,
    I am trying to write a JavaScriptx to convert idml file to PDF wbut I am not at all successful. When I try to open IDML file with JavaScriptx it always says "Unable to open file with no new name"....
    Can you please let me know some steps how to export idml as a PDF ?
    Dec 19, 2011 8:16 PM   in reply to micgat
    Hi Michèle,
    Thanks for your reply.
    Before you execute this code you need to open IDML file on server which actually gives issues. I tested your code on server and it says: "No documents are open".
    Thanx in advance for your kind consideration!
    As ever,
    VK
    Dec 20, 2011 12:39 AM   in reply to micgat
    Hi Michèle,
    Thanks a lot for your help. It has really helped
    Now I can export my IDML files to PDF
    Wonderful knoweldge sharing session by you which actually is needed to happen on forums!
    Cheers,
    VK
