blk.sheep
stage=null
Nov 14, 2011 9:07 AM
Loading an swf into a container swf, I'm getting the the #1009 error. I'm new to this syntax so I don't think I have it correct: The reisze listener is firing, and from the container swf I'm returning the trace
parent is null
stage is null
but my trace in the the listener using ADDED_TO_STAGE doesn't return anything at all. I'm not using classes.
Code for the external swf:
stage.addEventListener(Event.ADDED_TO_STAGE, ini);
function ini(e:Event):void {
    removeEventListener(Event.ADDED_TO_STAGE, ini);
    trace("stage after added to stage -" + stage);
stage.addEventListener(Event.RESIZE, resizeHandlerNews2);
function resizeHandlerNews2(e:Event){
        //stage.addEventListener(Event.ADDED_TO_STAGE,resizeHandlerNews2);
        trace("parent is " + parent);
        trace ("stage is " + stage);
        if(parent != null)
        trace("parent.parent is " + parent.parent);
    //var sw:int = int(stage.stageWidth);
    //var sh:int = int(stage.stageHeight);
I understand I need to get the stage to the display list to kill the null, and am perhaps a little confused as to why this wouldn't work.
thank you -
  • Peter Celuch
    Nov 17, 2005
    Nov 14, 2011 9:17 AM   in reply to blk.sheep
    Event ADDED_TO_STAGE is used in time when stage is not set. You don't add it to stage but to current object. This should work:
            if(parent != null)
  • Peter Celuch
    Nov 17, 2005
    Nov 14, 2011 10:12 AM   in reply to blk.sheep
    Allright, different angle: Tell me what exactly are you trying to achieve and paste code from LOADER swf and from LOADEE swf. So I can see thich one does what.
  • Peter Celuch
    Nov 17, 2005
    Nov 14, 2011 2:59 PM   in reply to blk.sheep
    Locate this piece of code in (each) loadee:
    and replace it with this:
    You have to access stage after the loadee was added to stage. I believe it will work now.
  • Peter Celuch
    Nov 17, 2005
    Nov 14, 2011 3:44 PM   in reply to blk.sheep
    In publish settings, is there Omit trace actions checked? You added the loaders to stage so anything you load should definitely fire addedToStage handler.
    Try a little check - put this code inside a loadee:
    addEventListener(Event.ENTER_FRAME, temp);
    function temp(event:Event):void {
         trace("stage: " + stage);
  • Peter Celuch
    Nov 17, 2005
    Nov 14, 2011 3:59 PM   in reply to blk.sheep
    put the trace statement outside the function - what does it say?
  • Peter Celuch
    Nov 17, 2005
    Nov 14, 2011 4:14 PM   in reply to blk.sheep
    So what was the problem in the first place?
    It seems we don't have a problem at all :?
    Change the code from
    to
    and it should be allright
  • Peter Celuch
    Nov 17, 2005
    Nov 14, 2011 4:16 PM   in reply to blk.sheep
    If any other error pops up, make sure you set "Permit debugging" to checked in Publish settings and paste the whole error message here. If you permit debugging, the error will tell you which line is wrong so you can locate it.
  • Peter Celuch
    Nov 17, 2005
    Nov 14, 2011 4:39 PM   in reply to blk.sheep
    stage: [object Stage]
    Outside of the temp function:
    I don't see "null" here.. it would be best if I had direct access to the files.
  • Peter Celuch
    Nov 17, 2005
    Nov 15, 2011 10:06 AM   in reply to blk.sheep
    I found the problem. The null references to stage in resizeHandler were actualy called from the previous swfs you loaded. Once you bound your swf with the stage through the listener, it can't be removed from memory after you're done using it. You always have to remove all listeners on object that you don't want to use anymore.
    I added destroy() funciton in your loadee - you should copy it to all loadees. And also changed the loader a bit, you'll find it, just search for "destroy".
    You can download fixed sources here: http://files.flashlabs.eu/stage_null_fixed.zip
  • Peter Celuch
    Nov 17, 2005
    Nov 16, 2011 12:05 PM   in reply to blk.sheep
    I can't compile news.fla because I'm missing RSSParser.as. Can you chare it as well?
  • Peter Celuch
    Nov 17, 2005
    Nov 16, 2011 2:24 PM   in reply to blk.sheep
    Well there's apparently more: now it wants some MailingList... don't you have those classes in one place so you can give it to me at once? And you don't have to pack FLAs again.. just classes.
  • Peter Celuch
    Nov 17, 2005
    Nov 16, 2011 4:12 PM   in reply to blk.sheep
    FIXED.
    I expanded the destroy function - since your code executes after few frames play, I added stop() in the destroy so we prevent the code from executing while the movie is considered destroyed.
    I also cleared the loader, removed its listeners and removed it from stage. You have to always remove all listeners in destroy method on all objects.
    And finally, in index.fla I added a variable _currentLoader with getter and setter since you have multiple loaders and load them at multiple locations. The setter basically clears previous loader and calls destroy upon its content.
    Don't forget to modify all loadee destroys according to this one: stop() and remove listeners. Take a look how I handler bannerindex - I put an IF statement there because destroy() can be called even before the last frame with script executed, thus bannerindex might still not be initialized and we would get null reference error.
  • Peter Celuch
    Nov 17, 2005
    Nov 16, 2011 5:28 PM   in reply to blk.sheep
    Yes, I see few things that need to be destroyed. The rssTextMC should have a destroy as well which will be called from the news' destroy.
    stage.addEventListener(Event.RESIZE, RSSstageResize);
    rssParser.addEventListener("dataWritten", onDataReceived)
    cssLoader.addEventListener(Event.COMPLETE, cssLoadComplete);
