Using iPad2 Camera in DPS publication
Nov 16, 2011 7:58 AM
Tags: #camera #ipad #ipad2 #html5 #digital_publishing_suite
We are investigating the feasibility of creating an HTML stack that would appear mid-issue, that would allow users to take a picture with their camera and insert in to the layout. Was wondering if this is possible within the DPS environment?
Much thanks!
Stephen
    Nov 18, 2011 2:44 AM   in reply to Stephen Barrante
    AFAIK you dont't get access to the Devices Camera with HTML.
    Nov 25, 2012 5:33 PM   in reply to Johannes Eckert
    I have been searching teh same topic, and have found this:
    http://www.html5rocks.com/en/tutorials/getusermedia/intro/
    Appears that using HTML5 it is possible to access camera, audio, accelerometer, GPS, etc by using a new API, navigator.getUserMedia()
    Does anyone else know if this works?
    Feb 1, 2013 5:42 AM   in reply to Cotton_Pete
    So no real-world experience in DPS? Would like to try use GPS location in DPS publication on local map...
    Feb 1, 2013 6:45 AM   in reply to Martin Lér
    You can use the camera inside DPS publications on devices running iOS 6 or later. This is a built-in feature of HTML in iOS6. Earlier versions of the OS don't have support for this.
    To access the camera use something like this:
    <input type=file accept="video/*">  (for video files)
    <input type=file accept="image/*"> (for pictures)
    There isn't any way to get at the GPS in a DPS publication currently.
    Neil
    May 14, 2013 2:28 AM   in reply to Neil Enns - Adobe
    This is correct for images that has been taken by the device-camera already. Unfortunately this is not written clearly.
    So yes, you can access the photo and video library on your device to upload a static / motion image which has been already taken by user.
    But you cannot implement a live image of the device-cam in your DPS publication yet. This has to be implemented in iOS WebKit through getUserMedia which is not likely to be implemented before iOS7 is coming out (and I have no clue if it will be included there).
    May 14, 2013 9:48 AM   in reply to Neil Enns - Adobe
    Depending on your needs, you can use the Google Maps API for geolocation, I don't know if it using the devices actual gps or just wifi for loaction data, but it does work.
    May 14, 2013 9:51 AM   in reply to jkuhns5
    For Geolocation (which is another question) you surely can use the geolocation feature of HTML5.
