11.0 Coding of H.264 playback when there is no mosaic, but when coding a mosaic 11.1, why the more upgrades but weak, and my code is also not changed.
11.0 H.264 encoding moves in front of the camera, not a mosaic, but 11.1 in the front of the camera movement, the mosaic will be significant, ask how is this going? ?
No one know, 11.0 H.264 encoding is very good camera, why 11.1 is on the move there will be obvious mosaic.
11 The important feature of H.264 is not you, why did not the official answer to this question ah, so I am very sorry, more than 11.0 11.1 Why so much difference between the H.264 encoding ah? ?
https://bugbase.adobe.com/index.cfm?event=bug&id=3047043,This is my proposed.
Third,I play stream, both in stationary and mobile is not the time, there is no difference, but once moving together, 11.0 can quickly restore the picture perfect, just like when it was stationary, but 11.1, it will be apparent mosaic, After about two seconds into the rest of the screen to restore, in the 2 seconds, the screen is very bad, obviously mosaic
Two are in violent shaking my hand when the next cut, because my country a slow connection, I limit the bandwidth is 30KB per second, could you be tested under the high-bandwidth, low bandwidth, but be sure to keep under experience. You can see in my code cam.setQuality (30000,0);
But I do not know the specific reasons for that, just in front of that speculation.
https://bugbase.adobe.com/index.cfm?event=bug&id=3005174 I guess because the fix this BUG, \u200b\u200bcaused. In fact, not good, if not repaired.
Please advise the specific reasons,
and I hope can be restored to 11.0 in 11.2 look like.
The answer is provided in the comment section of the following bug;
I've also posted Jozsef notes below;
In Flash Player 11.1, we have changed the bitrate control for H.264 from variable bitrate (VBR) to constant bitrate (CBR). You can try two things:
1 - Use higher bitrate
2 - Set the quality
Because I am going to use your RTMFP, FMS4 in peer assistance, but most people in China are using ADSL, you know, ADSL uplink and downlink is not the same, the download speed may have 200KB, but the upload speed of ADSL only 30KB per second, so I can only speed 30KB, in order to better use this feature, I think that using VBR is very necessary! !
North America
Asia Pacific
