    Nov 22, 2011 1:13 PM   in reply to Maribeth R
    Maribeth,
    The problem with the HD 6870 is that it, like all other ATi or AMD GPUs, is not supported at all in CS5's MPE GPU accelerated mode. Therefore, all ATi GPUs will force CS5 to run only in MPE software-only mode.
    Nov 25, 2011 2:16 PM   in reply to Maribeth R
    Maribeth, since you have one empty memory slot now, you should get 2 memory modules, both 4GB.
    Also, as stated before, it would be a huge waste to get a non-Nvidia GTX card for Premeire use. To be clear to a point, it is a big deal.
    Best of luck.
    Dec 18, 2011 1:49 AM   in reply to Maribeth R
    Mac?.....
    NO.
    Current macs can't be configued to run Mercury Playback hardware acceleration unless you spend a bank on a Mac Pro and a Nvidia Quadro GPU that will alone cost nearly as much as a properly configured PC.
    Macs can work with CS5.5, but it is not the best option getting started.
    Dec 19, 2011 1:31 PM   in reply to Maribeth R
    Maribeth,
    The problem with your situation is that none of the pre-builts from the big companies are suitable for video editing (at least not without having to either spend an exhorbitant amount of money or feel comfortable opening up the computer case and manually adding the parts all by yourself).
    Why? Because although their base configurations are attractively priced, these companies will steal you blind when it comes to upgrading such a system with even the minimum number of components that Adobe requires just to even run Premiere Pro CS-anything satisfactorily. You see, Adobe requires a minumum of two fast, internal hard drives (three or more are even better), and that only Nvidia GPUs with 1GB or more RAM can run CS5.x with MPE GPU acceleration at all.
    Unfortunately, Apple does not currently offer any system at all whatsoever with an Nvidia GPU (that company's systems offer either integrated Intel HD graphics or AMD/ATi discrete GPUs).. And even more restrictive, the only Macs capable of using MPE GPU acceleration at all are the full-tower and super-expensive Mac Pros (of which the currently available models are mere carryovers from 2010, with no new CPUs or GPUs offered); that's because anything less than a Mac Pro are all self-contained and not user-upgradable at all except for the RAM. Furthermore, the only current-generation Nvidia desktop or workstation GPU that's compatible with Macs is the $800~$900 Quadro 4000.
    As for the other brands like Sony and HP, the cases that their systems are housed in are way less than optimal for an editing rig: They are seriously cramped and provide extremely poor (extremely low) airflow. Plus, they often cannot accommodate long graphics cards at all or more than two disks.
    So, in other words, don't go to any of those big-name companies for a custom PC build or a pre-built: They either charge you an exhorbitantly high price for even a minimally adequate configuration for editing or they do not offer such a robust required configuration at all. Instead, go to a smaller custom builder such as ADK who knows how to custom-configure a PC that's suitable for some heavy-duty video editing (these editing-specific companies charge a couple of hundred dollars more than an assemble-it-yourself PC made up of those exact same components).
    Dec 21, 2011 12:45 AM   in reply to RjL190365
    I agree with RjL190365.
    Apr 12, 2012 3:32 PM   in reply to Maribeth R
    Maribeth R wrote:
    I got a quote from ADK and I have asked a few peeps their opinion and they think it's a bit high.
    Remember that you are not paying just for the hardware. Of course it would be cheaper to build it yourself.
    You are paying for their knowledge and ability to asssemble a system which is properly set up and will work efficiently and be stable.
    I'm a satisfied customer.
