Script for removing color definitions
Nov 17, 2011 9:24 AM
I'm trying to create a script that will remove color definitions other than the default plus our corporate colors. I'm thinking some kind of "while" loop to go through the doc's color list, matching it to an array of named colors.
I see that there is a Color object and methods such as Delete(), but it's not coming together for me.
Any help would be appreciated.
    Nov 17, 2011 10:34 AM   in reply to Milo G
    I am posting a small snippet which demonstrates how to traverse the color object in doc and delete it. The following sample iterates over all the color present in the doc until it finds a color named “testcolor” and then deletes it. It works on the active document.
    doc = app.ActiveDoc   //getting the active doc
    col  = doc.FirstColorInDoc   //getting the first color in doc
    while (col.ObjectValid() )  //checking if the color object is valid
        if (col.Name == "testcolor" )  // matching for testcolor
            col.Delete()  //deleting the color
            break
    else {
    col = col.NextColorInDoc
    Regards,
    Vikash
    FrameMaker Engineering team
    Dec 14, 2011 2:25 AM   in reply to Milo G
    You are using "break" in the while loop which will terminate the loop whenever the condition is true. Try the following snippet:
    while( col.ObjectValid() )
         if (col.Name <not in> (keepColors) )  //Color doesn't exits
              col2 = col.NextColorInDoc
              col.Delete()
              col = col2
         else{
    Regards,
    Vikash
    Frame Engineering Team
    Dec 14, 2011 7:47 AM   in reply to Milo G
    The problem is that (col.Name in keepColors) does not work on the string value of the array element. It is checking for the element's name which in an array is its index value. The way to do this is to create a for loop to check each value of the array against each color in the document.
    Ian
    Dec 14, 2011 3:27 PM   in reply to Milo G
    Try this as one way to solve the problem. It adds a new contains() method to the Array class.
    var doc = app.ActiveDoc,
        keepColors = ["Black","White","Red","Green","Blue","Cyan","Magenta","Yellow","Dark Grey","Pale Green","Forest Green","Royal Blue","Olive","Salmon","Mauve","Light Salmon","Custom Color"];
    Array.prototype.contains = function (value) {
        var i;
        for (i = 0; i < this.length; i+=1) {
            if (this[i] === value) {
                return true;
    while(col.ObjectValid()){
        if (!keepColors.contains(col.Name)) {
            col2 = col.NextColorInDoc;
            col.Delete();
            col = col2;
        else {
            col = col.NextColorInDoc;
    Dec 15, 2011 9:56 AM   in reply to Milo G
    Milo,
    In JavaScript it is possible to extend the built-in classes. Normally the Array class has no method for testing if it contains an element with a specific value. The new anonymous function simply checks each element in the array and returns true if it matches the value parameter.
    Aother useful way to extend the Array class would be to add an indexOf() method this could return the index number of a given value, or -1 if the value is not found.
    Ian
