The message pretty well spells it out. There are two very likely options and one possible option.
1. The password and login are not correct (very likely)
2. The other FTP settings (server address or root folder) are not correct (again, very likely)
3. The folder "htdocs" doesn't exist on the server (possible if you have never successfully connected and uploaded any files, but that probably isn;t why you're seeing this)
Double check your FTP setting against what your host gave you. Check with your host to see if you MUST use passive FTP or secure FTP to connect.
Download Filezilla and input your FTP settings, then try to connect with it. If it can connect and DW can't get back to us.
Karlhevera wrote:
I have found that I do not have a htdocs file on my local site.
Did you check your FTP settings in Dreamweaver as has been previously mentioned? Make sure they are set to 'passive'.
If you can connect using another FTP client then its certainly a Dreamweaver issue. Personally I have never been that impressed with the built in FTP and stopped using it years ago.
he is a shot of the ftp screen.
Also:
To view this FTP site in Windows Explorer: press Alt, click View, and then click Open FTP Site in Windows Explorer.
11/24/2011 09:56AM Directory htdocs 11/29/2009 12:00AM Directory logfiles 11/29/2009 12:00AM Directory private 05/21/2011 12:00AM Directory v3flashslideshow
North America
Asia Pacific
