Placing Word File with Character Styles
Nov 22, 2011 11:50 AM
InDesign CS5, windows 7
I am hoping for some guidance.
I am creating a directory from an Excel file.  This is what I have done and where I am at.
1. Edited Excel File to ad "Headers" for Name, Address, etc...
2. Used Mail Merge in MS word to create a Directory.
     - Created Character Styles in word for different fields.
     - Did some minor editing to remove stray spaces, etc...
3. Placed wrod file in InDesign.  Layout is created with basic text boxes that are split into 4 columns, each box linked to the next (I have about 30 pages of this).
At first, this was working OK, but the CHaracter styles were not coming through (Actually, they were lost during the merge in Word).  So, I did some work and found that there was a code I could add to the Merge Fields oin Word to force the Character styles to be retained.
Anyway, I did that.  However, now when I place the Word File in InDesign, it appears to hang at "Processing Character Styles".
I removed the code from the merge, figuring I could go back, but I still get that hang.
Any suggestions are appreciated...
-kaz
    Nov 22, 2011 1:46 PM   in reply to Karl B Cartwright
    I think I followed most of your explanation. But, since we can't see what you're doing, it's hard to know 100% what your reasons are for doing what you do. F'rinstance, I wonder why you're bothering with the Word merge at all. Without knowing why you have to run the merge in Word, I'd suggest this:
    add headers to your Excel file
    save out .csv
    Use InDesign's Data Merge tool, skip Word entirely
    Why do you need to use Word's Mail Merge? If you've never used Data Merge in ID, you should probably take a look at the Help file entry to see if it will work for you.
    Nov 22, 2011 4:21 PM   in reply to Karl B Cartwright
    Depends on what you mean by a directory style merge. I use ID's Data Merge to do an annual directory for a local organization, and I think many other users do similar work. Yes, each record becomes a separate text frame, so editing is not necessarily as easy as it might be in Word (never done a mail merge in Word), but there are scripts that will thread the individual frames intoa single story if you need that.
