seriousfretter09
Load a PDF in StageWebView - iOS
Nov 23, 2011 8:06 AM
Tags: #help #pdf #flash #ios #builder #load #webview
I am trying to create an iOS app that loads my companies product catalogue into a webview stage. I cannot figure out after a lot of google how to access this local file, although external files load fine. I'm trying to use the "file:" command. I'm doing this in flash builder.
<![CDATA[
                              import flash.display.MovieClip;
                              import flash.media.StageWebView;
                              import flash.geom.Rectangle;
                              var webView:StageWebView = new StageWebView();
                              var yOffset = 47
                                             public function FestoKP() {
                                                       webView.stage = this.stage;
       webView.viewPort = new Rectangle( 0, yOffset, stage.stageWidth, stage.stageHeight - yOffset);
       webView.loadURL( "file:///asset/Festo_KP_Catalogue.pdf" );
                                                       closeBtn.visible = true
       public function Close() {
       webView.stage = null;
       closeBtn.visible = false;
    Feb 2, 2012 5:18 AM   in reply to seriousfretter09
    I am on the same boat.  Did you ever find a good working example? -I'm about to give up.
    Feb 7, 2012 11:00 AM   in reply to seriousfretter09
    These guys at "CultCreative" seem to have the ideal solution for FB (it even checks to see if a newer .pdf is on a server)  but my project was built in Flash Pro CS5.5 so again just want to load a few local .pdf files which would be bundled up with the app.
    http://www.cultcreative.com/tutorials/11/13/2011/local-file-access-edi ting-for-android-and-ios/
    I'm still interested in the method you used for iOS if it works well with Air (3.1) for iOS.   However, I am determined to find a way of using Flash Pro CS5.5 to do so.   Thanks! -if you can find it, and think your AS3 from FB would work for me.
    Feb 17, 2013 12:35 PM   in reply to seriousfretter09
    This was perfect thanks!
