Computer_Dude
Premiere Elements 9 Media Cache Files
Nov 26, 2011 8:45 AM
Tags: #premiere_elements_9 #scratch_disks #media_cache_files
Hello,
So, here's the deal. I have 4 hard drives, and I have Adobe Premiere Elements 9 installed on C:, with the scratch disks on D:, E:, and F:,(all internal drives).  Just a couple days ago, I had to re-install Windows, becaue I upgraded my mobo & processor. I then re-installed Premiere and re-assigned it's scratch disks, but I'm not sure I got all the right disks for each category. I currently have it using drive E as the Media Cache Folder, but I just found a ~95GB Media Cache folder, containing 1,378 files, some of which are "Adobe Premiere Elements File", and some are "MPGINDEX Files",  on F:, which I'm assuming is from the other install. Is it safe to delete those Media Cache Files on F:, since Premiere isn't currently using them? Will I be in any danger of losing any of my projects or videos by doing that?
Austin
    Nov 26, 2011 9:12 AM   in reply to Computer_Dude
    Media Cache files are transient so you do not need to keep them. I have a folder called 'Hold4Delete' that mirrors my disk structures. Then, when I'm doing any significant tidying up, I move items for deletion into that folder structure. If after a month nothing has gone wrong I delete them properly.
    Cheers,
    Neale
    Nov 26, 2011 4:33 PM   in reply to Computer_Dude
    As I understand it Media cache files are only used when you render any part of the timeline. If you deleted them then only this rendering will disappear and the red lines will reappear.
    It won't affect your project that can always be rendered again if you really want to preview it again.
    Rendering is done anyway when you eventually share it to anything. It might just take a little longer.
    Someone correct me if I'm wrong!
    Nov 27, 2011 11:17 PM   in reply to Computer_Dude
    There are several PrE caches.  All of the caches can be deleted without issue  -- but don't delete the capture video and audio directories without first verifying they can be deleted.  I would recommend deleting the cache directories with a new O/S install because some of the cache entries may just be eating up space or may be even duplicated with the new install.
    The side effect of deleting the cache will be additional time in opening up the project because the cache will need to be rebuilt or poor performance because the preview caches are not available.
    For future reference, there seems to be two types of cache and a holding directory...
    a) Media cache
    b) Project cache
    c) Capture holding directories.
    The media cache is not project specific and will be shared between projects.  This consists of the media cache database (under 'Media' in Preferences) and the actual media cache (under 'ScratchDisks' and 'Media Cache' in Preferences).  Files are created here when PrE index and conforms media items -- usually this is when a new media item is addded to a project.
    The project cache (under 'ScratchDisks': 'Video Previews', 'Audio Previews', and 'Disc Encoding' are specific caches for a project.
    The capture holding directories (under 'ScratchDisks': 'Captured Video' and 'Captured Audio') are holding directories for captured video and audio.
    NEVER delete anything under the catalog directory.  Many items cannot be rebuilt.
