ChrisP500
Flash Player streaming video keeps freezing while audio continues
Nov 26, 2011 5:16 PM
I have been having a problem with flash player for a couple of months now. When watching streaming video's the video will freeze for a second every 5-10 seconds constantly, but the audio continues uninterrupted. I have tried everything, enabling/disabling hardware acceleration; reinstalling flash player 11; trying flash player 10; updating the graphics drivers. I have also tried it on 5 different browsers: IE, Firefox, Chrome, Seamonkey (mozilla browser), and Opera. The same problem occurs on all of them. Yesterday I thought I had cracked it when I realised I had several versions of java installed and once I deleted all the old versions flash player worked fine. However, today the problem has started all over again, and for some reason flash player had deleted itself when I turned the computer on this evening.
I have checked my internet connection speed online and am running an average speed of 5Mbps. I have 2.5 GB's of RAM, and a 2.2 GHz AMD Athlon 64 3500+ processor. I am using Windows XP. I have never had any problems with flash player on this pc (which I've had for 6 years), and as far as I can tell this problem started occurring a couple of weeks before flash player 11 was released.
I'd be very grateful for any help anyone can give resolving this problem.
Regards,
Chris Perkins
  • Xircal
    Mar 29, 2011
    Nov 28, 2011 1:42 PM   in reply to ChrisP500
    Can you post a couple of links where this problem occurs?
  • Xircal
    Mar 29, 2011
    Nov 28, 2011 2:10 PM   in reply to ChrisP500
    ChrisP500 wrote:
    Hi Xircal,
    Not sure what you mean, this problem occurs with all streaming video I try and watch in fullscreen (and sometimes in small screen) regardless of the site.
    So if you try to view this video, you get the problem? http://youtu.be/LMhBuSBemRk
  • Xircal
    Mar 29, 2011
    Nov 29, 2011 3:25 AM   in reply to ChrisP500
    Try running Firefox in Safe Mode. That disables all your add-ons which are located in the Extensions menu (press CTRL+SHIFT+A to access), but leaves your plugins running.
    To restart Firefox in Safe Mode, press the ALT key to get the text links (only necessary if you're using the interface with the oblong orange Firefox button top left) and then click "Help" | "Restart with add-ons disabled" When you see the menu, click the button called "Continue in Safe Mode" without checkmarking any of the boxes.
    If it runs properly in that configuration, then one or more of your add-ons is the culprit.
  • Xircal
    Mar 29, 2011
    Nov 30, 2011 4:50 AM   in reply to ChrisP500
    Try running the videos in HTML5 instead of using the Flash player. To do that on Youtube, go to http://www.youtube.com/html5 and click the link at the bottom called "Join the HTML5 trial". Then try viewing a few again.
    Dec 1, 2011 6:12 AM   in reply to Xircal
    Hi guys
    i have posted the same question without seeing yours Chris. the perfect match is the period when it occured and the flash player behaviour. i have tried a lot of solutions ( if you want to check it, please read my post, maybe something will work for you). thanks for your solutions Xircal, unfortunately they didn't worked, none of them.
  • Xircal
    Mar 29, 2011
    Dec 1, 2011 6:40 AM   in reply to giuliano.m
    Mozillazine has a good troubleshooting page to address Flash issues. Can you both have a look at that? http://kb.mozillazine.org/Flash#Flash_player_not_working_on_certain_we bsites
  • Xircal
    Mar 29, 2011
    Dec 2, 2011 1:46 AM   in reply to ChrisP500
    ChrisP500 wrote:
    I think the issue may be related to Silverlight which I think was released in September when we both started getting this problem. DIsabling it does not work, so I'm still not sure how or if it really is causing this problem.
    If the player is Silverlight, you'd be able to see that by right clicking the video.
    Can you go to Youtube, play any video and then right click it and choose "Take Speed Test". That will take you to a graph where you can see what your download speed is in relation to your ISP, your location and other data. If the black bar is way down compared with others, then I would suspect that something, or somebody else is using your bandwidth. Do you have wireless? If so, change the security code. It may be being used as a wireless hotspot by your neighbours.
    You can also play the test video which will show data usage in real time.
    Dec 3, 2011 7:47 AM   in reply to Xircal
    Thanks for your answers. Yes indeed i suspected myself of silverlight wich i disabled and uninstall a month ago. But nope. Nothing happend. About the network connection.......this is very interesting because now i live in a block (the problem started when we moved, so,  i don't know if this is a coincidence or.....) and all the neighbours have the same antena, so we have a public network connection. If this is the cause, well,...... this beats me off, because i don't think i can do to much about it. What do you think? Can this be actually the real problem?
  • Xircal
    Mar 29, 2011
    Dec 3, 2011 10:46 AM   in reply to giuliano.m
    Very difficult to say. I would think your first port of call should be to your ISP's helpdesk. They have the tools to check your connection and determine if there are any problems with it.
    Do your neighbours experience the same kind of problems as you?
  • Xircal
    Mar 29, 2011
    Dec 4, 2011 8:28 AM   in reply to ChrisP500
    You're welcome.
