• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
junitreport 'redirect' is not allowed when the secure processing feature is set to true.
New Here ,
Nov 27, 2011 Nov 27, 2011
Hello,
   I'm running flexunit4.1.0-8 and I have an ant script running the test suite.    I recently upgraded from FB 4 to 4.5 and now I'm getting
failures on junitreports.  Here's the full error:
[junitreport] : Error! Use of the extension element 'redirect' is not allowed when the secure processing feature is set to true.
[junitreport] Failed to process C:\TDMSE_2_6\tdmse\flex-test\flex_unit_reports\TESTS-TestSuites.xml
BUILD FAILED
C:\TDMSE_2_6\tdmse\build\flexunitbuild.xml:116: Errors while applying transformations: javax.xml.transform.TransformerException: java.lang.RuntimeException: Use of the extension element 'redirect' is not allowed when the secure processing feature is set to true.
Here's the junitreport section:
<target name="flex-unit-execute-tdmse-test-runner"
                              description="executes the test runner app">
          <flexunit swf="${FLEX_UNIT_TEST_HOME}/TDMSETestRunner.swf"
                              toDir="${FLEX_UNIT_REPORTS_HOME}"
                              haltonfailure="false"
                              localTrusted="true"
                              verbose="true"
                              headless="false"/>
          <junitreport todir="${FLEX_UNIT_REPORTS_HOME}">
                    <fileset dir="${FLEX_UNIT_REPORTS_HOME}">
                              <include name="Test-*.xml"/>
                    </fileset>
                    <report format="frames" todir="${FLEX_UNIT_REPORTS_HOME}/html"/>
          </junitreport>
</target>
And here's the full ant build:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE project>
                         TDMS flex unit test suite
$Author:: hermannee                                                            $
$Revision:: 10963                                                              $
$Date:: 2011-11-15 13:38:46 -0500 (Tue, 15 Nov 2011)                           $
$URL:: svn://ehsntpvld03.niehs.nih.gov/dev/tdmse_test_suite/trunk/build/flexun#$
          <!-- **** ADD THIS TO tdmes/build/build.xml *************
          <property name="FLEX_UNIT_HOME" value="${tdmsedir}/../tdmse_test_suite" />
          <target name="run_flex_units">
              <ant antfile="${FLEX_UNIT_HOME}/build/build.xml" />
          </target>
<project name="flexunitbuild" basedir="." default="flex-unit-start-test-runner">
          <tstamp>
                    <format property="build.date" pattern="MMMMM dd, yyyy" />
                    <format property="build.time" pattern="HH:mm:ss" />
          </tstamp>
          <property name="tdmsedir" value="${basedir}/.." />
          <property name="builddir" value="${tdmsedir}/../build" />
          <property name="FLEX_HOME" value="${builddir}/tools/flex-4.5.0" />
          <property name="PARSLEY_HOME" value="${builddir}/tools/parsley-2.4.0" />
          <property name="FLEX_UNIT_HOME" value="${tdmsedir}/flex-test" />
          <property name="FLEX_UNIT_LIBS_HOME" value="${builddir}/tools/flexunit-4.1.0-8" />
          <property name="FLEX_UNIT_REPORTS_HOME" value="${FLEX_UNIT_HOME}/flex_unit_reports" />
          <property name="FLEX_UNIT_TEST_HOME" value="${FLEX_UNIT_HOME}/flex_unit_tests" />
          <!-- ==== tasks ============================ -->
          <taskdef resource="flexTasks.tasks" classpath="${FLEX_HOME}/ant/lib/flexTasks.jar"/>
          <taskdef resource="flexUnitTasks.tasks" classpath="${FLEX_UNIT_LIBS_HOME}/flexUnitTasks-4.1.0-8.jar" />
          <!-- dev -->
          <echo>basedir: ${basedir}</echo>
          <echo>tdmsedir: ${tdmsedir}</echo>
          <echo>builddir: ${builddir}</echo>
          <echo>FLEX_HOME: ${FLEX_HOME}</echo>
          <echo>FLEX_UNIT_HOME: ${FLEX_UNIT_HOME}</echo>
          <echo>FLEX_UNIT_LIBS_HOME: ${FLEX_UNIT_LIBS_HOME}</echo>
          <echo>FLEX_UNIT_REPORTS_HOME: ${FLEX_UNIT_REPORTS_HOME}</echo>
          target: run-tdmse-test
          <target name="flex-unit-start-test-runner"
                              description="clean, compile and run tdmse flexunit tests"
                              depends="flex-unit-clean-tdmse-tests,
                              flex-unit-tdmse-compile-test-suite,
                              flex-unit-execute-tdmse-test-runner"/>
          <target name="flex-unit-clean-tdmse-tests" description="Cleans the FlexUnit test and reports directories">
                    <delete dir="${FLEX_UNIT_REPORTS_HOME}" failOnError="false"
                                        includeEmptyDirs="true" />
                    <mkdir dir="${FLEX_UNIT_REPORTS_HOME}" />
                    <delete dir="${FLEX_UNIT_TEST_HOME}" failOnError="false"
                    <mkdir dir="${FLEX_UNIT_TEST_HOME}" />
          </target>
          <target name="flex-unit-tdmse-compile-test-suite">
                    <mxmlc file="${tdmsedir}/flex-src/TDMSETestRunner.mxml"
                                        output="${FLEX_UNIT_TEST_HOME}/TDMSETestRunner.swf">
                              <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml"/>
                              <!-- ==== include tdmse resource bundles ====== -->
            <locale>en_US</locale>
            <source-path path-element="${tdmsedir}/flex-src/locale/{locale}" />
            <include-resource-bundles>COMMON</include-resource-bundles>
            <include-resource-bundles>OW</include-resource-bundles>
            <include-resource-bundles>PREF</include-resource-bundles>
            <include-resource-bundles>RD</include-resource-bundles>
            <include-resource-bundles>RG</include-resource-bundles>
                              <!-- ==== compile parsley library ============= -->
                              <compiler.library-path dir="${PARSLEY_HOME}" append="true">
                                        <include name="parsley-flex4-2.4.0.swc" />
                                        <include name="spicelib-flex-2.4.0.swc" />
                              </compiler.library-path>
                              <!-- ==== compile all tdmse flex-src ========== -->
                              <source-path path-element="${tdmsedir}/flex-src" />
                              <source-path path-element="${tdmsedir}/flex-test" />
                              <!-- ==== compile all flexunit swc's ========== -->
                              <compiler.library-path dir="${FLEX_UNIT_LIBS_HOME}" append="true">
                                        <include name="*.swc"/>
                              <compiler.library-path dir="${FLEX_UNIT_LIBS_HOME}/mocklibs" append="true">
                              <compiler.verbose-stacktraces>true</compiler.verbose-stacktraces>
                              <compiler.headless-server>true</compiler.headless-server>
                    </mxmlc>
          </target>
                                        localTrusted="true"
                                        verbose="true"
                                        headless="false"/>
                              </fileset>
                    </junitreport>
          </target>
</project>
I haven't seen much info about this problem anywhere on google except for this forum post:
http://forums.adobe.com/thread/740146
Thanks for any help!
TOPICS
FlexUnit
Views
5.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Mar 15, 2012 Mar 15, 2012
LATEST
If you include the xalan.jar library to the build.xml execution classpath everything works!!!!!!.
I hope it will be userfull.
Votes
Translate
Translate
Report
Report
