I've got a file (one of 3) I've been given to create a smaller file (320x480) from.
The (problem) file is an avi file and plays (video and audio) just fine in the native Windows media player. (I'm on Windows 7 Ultimate 64-bit) There are no issues of memory or HDisc space.
Video:
MPEG-4
The file is 2:21:29 in length.
720x480
Data rate 1489kbps
Total bitrate 1617kbps
29 frames/second
Audio:
Bit rate 128kbps
Channels 2 (stereo)
Audio sample rate 48 kHz
The file is about 1.6Gb
This is one of 3 I recieved. The other two were of comparable specs (file format, codec, etc.) and similar length (not exactly but one was slightly longer, the other shorter.)
The problem is that this particular file (the other two import perfectly), when imported, only comes in as an audio file. No video imports. The other files import as audio and video. No error message either.
I've imported all kinds of video files in the past with different frame sizes, rates, and aspect ratios, and codecs, yet I've never had one that only imports the audio without the video.
Suggestions?!
Do this:
@ECHO OFF
for %%a in (*.avi) do ffmpeg -i "%%a" -vcodec copy -acodec copy -f mp4 -y "%%~na".mp4
Report any troubles. If it doesn't work, grab MediaInfo and use it to analyze the file; you can use Text mode to copy and paste the results of the file analysis here.
Thanks Colin,
but... I tried this and while the process seemed successful (if a tad tedious), to the point of creating an mp4 file that was slightly smaller in size by about 13Mb and that plays perfectly well in Windows Media Player.
However it now doesn't import at all into Premier Pro CS 5.5 now and I get an error (where I got none previously) that says:
File Import Failure
Error Message:
The file has no audio or video streams.
I used Media info for the first round of info. I can attach a txt file if needed. If I do so, should it be of the original avi or the converted mp4 file?
Here's the media info on the original avi:
General
Complete name : lcn35LE-2.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 1.63 GiB
Duration : 2h 24mn
Overall bit rate : 1 617 Kbps
Video
Format : MPEG-4 Visual
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 2h 24mn
Bit rate : 1 474 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.142
Stream size : 1.49 GiB (91%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 2h 24mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 132 MiB (8%)
Alignment : Aligned on interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 408 ms
can you split the avi to a small sample and share it? Ive had probs like this and i cant remember exactly what I did..but it had to do with using virtualdub and maybe one other program.. one for the sound file and one for video...sync wasnt an issue but who knows what will happen if you follow this thru.
I can't send out a piece of the file since the NDA I signed prevents it. Besides, since Premeire is the only editing program I have (that I know of) I can't even get it to import to split it.
In case it's of any use, there appears to be no sync errors with the sound when playing it on Windows Media player. The audio is a simple 2 channel stereo stream.
If I clipped a piece out and then blanked out the video (not deleted, but redacted), would that help or would that defeat the purpose? You may not have done work for anyone with an NDA, but it is not something to be taken lightly. Much of my work (and client loyalty) requires the security of nondisclosure more often for IP, but occasionally for govt regulation.
if you split file to small segment for sharing ( to troubleshoot ) DONT do anything to the file except split it. otherwise theres no point IMO.
get virtualdub ( Free )...open your avi... leave everything at the default settings .... use " save as AVI " and rename the file to what you want for testing...( different than your original avi ).
try to import it to editor...see what happens.
xvid is wanky ...is for 'viewing' not editing...but you might get something decent out of virtualdub ( which is a great program even though it is free )
post results
the sync prob wouldnt be until AFTER the export from virtualdub and test how it worked out
North America
Asia Pacific
