BJ-012345
Can't find high contrast setting
Nov 30, 2011 9:10 AM
I believe 1.8 preview 2 has a high contrast setting. I can't find it anywhere. Can anyone point me to it? I need to get white text on black.
    Dec 2, 2011 11:32 PM   in reply to BJ-012345
    You may try to switch to the Windows high contrast mode first by pressing left SHIFT, left ALT, and PRINT SCREEN keys together. For Windows XP, there is an "Accessibility" item on Control Panel which can adjust the high contrast color (from Display tab). For Windows Vista / 7, just change the Windows theme from Personalize.
    Good luck!
    Derek
    Dec 4, 2011 6:29 PM   in reply to BJ-012345
    Have you tried to enable high contrast mode as what I mentioned above? "High contrast mode" for Windows is a "flag", which cannot be enabled by a certain color combination. You may switch to enable it first and then choose the color theme like white text on black.
    BTW, I can get correct color from 1.8 on my Windows XP. I'm sure you can get it as well, following the way above.
    Apr 24, 2012 3:06 PM   in reply to Derek Leng
    I am not seeing an explicit option in Preview 3 to enable a "high-contrast" reading mode. Some of us desire to read text for an extended period on a dark ground out of preference, not absolute necessity, and forcing all of those who have the desire to use high-contrast for reading EPUB to do so across all of Windows is as poor of an accessibility choice (choices have implications both ways, and it's short-sighted to ignore either those who need accessibility or those who don't as their needs often overlap) as not supporting it at all.
    May 22, 2012 12:02 AM   in reply to Matt Lewandowsky
    Hi Matt Lewandownsky,
    My understanding is to provide a feature that support night reading mode. Is that true? If yes, I'll forward this request to the product team. Thanks for the request.
    Thanks and regards,
    Derek
    May 30, 2012 2:24 AM   in reply to Derek Leng
    If you want to call it a "night reading mode", sure.
    Basically, all I'd be requesting is "Provide high-contrast mode via menu toggle as well as Windows UI hints." This would ideally create the side-effect that it could be disabled by those who normally use high-contrast mode for their apps, but may actually prefer to not use ADE in high-contrast mode.
    This is one of those cases where defaults are unlikely to suit everyone and a toggleable would be useful. (On by default if the OS is configured for "high contrast" and off otherwise.)
