vin2k4u
Adding Childe Node to the XML
Dec 1, 2011 2:39 AM
Hello Geeks,
Need your help on solving the below issue.
Am using Adobe Livecycle Workbench ES2 for creating a Process.
The requirement is to Add a Child Node to the XML.
<helpUrls>
HelpUrl>
Name>BugReport</Name>
url>C:\BugRep.exe</url>
HelpUrl>
helpUrls>
Need to add Child Node
<helpUrls>
HelpUrl>
HelpUrl>
          <HelpUrl>
Name>IssueReport</Name>
url>C:\IssueRep.exe</url>
HelpUrl>
</helpUrls>
The Schema Looks as below
<xs:element name="helpUrls">
<xs:complexType>
   <xs:sequence maxOccurs="unbounded">
    <xs:element name="HelpUrl">
     <xs:complexType>
       <xs:element name="Name" type="xs:string" />
       <xs:element name="url" type="xs:string" />
      </xs:sequence>
     </xs:complexType>
   </xs:element>
  </xs:sequence>
</xs:complexType>
</xs:element>
Thanks in advance
Regards
Darsh
    Dec 5, 2011 1:00 AM   in reply to vin2k4u
    This you cannot do in a direct way.
    You can add the node <HelpUrl with a different name for example <TempUrl> and then rename the tag name into HelpUrl using XSLT activity. Otherwise the latest node will overwrite the existing HelpUrl node.
    Nith
    Dec 5, 2011 7:52 AM   in reply to vin2k4u
    A Sample XM File after adding a <temp> tag would look like:
    <root><HelpUrl>some URL1</HelpUrl><HelpUrl>some URL2</HelpUrl><temp>New URL</temp></root>
    The XSL used to rename the above XML is as follows:
    <?xml version="1.0"?>
    <xsl:stylesheet version="1.0"
    xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
    <xsl:template match="/">
    <root>
          <xsl:for-each select="root/HelpUrl">
                        <HelpUrl>
                                  <xsl:value-of select="."/>
            </HelpUrl>
          </xsl:for-each>
          <xsl:for-each select="root/temp">
            <HelpUrl>
              </HelpUrl>
          </xsl:for-each>
    </root>
    </xsl:template>
    </xsl:stylesheet>
    I hope you can understand from the above example on how to rename a tag using XLST.
    Send me your email address so that I can send you the sample process I tried for you.
    Nith
    nith.igate@gmai.com
